Catalytic Converters?
Old Sep 2, 2005 | 12:41 PM
ken93vette's Avatar
ken93vette
Default Catalytic Converters?
I just found out that my 93 which would not pass emissions was all due to the catalytic converters are shot. The temp going in is 500 and coming out is 400 when I guess it should be hotter like 700.
They are saying $400.00 each for direct fit. The car is already loud enough due to the current aftermarket exhaust (it is stainless with dual tips, can't figure out which brand). The shop said that any high performance cat is going to make it louder again.
Does anyone have any suggestions of brands, want them to be direct fit?
Old Sep 2, 2005 | 01:05 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
TLD (The Last Detail) shows rebuilt stock converters in their catalog. $285 one side and $295 the other, with a core exchange.
Old Sep 2, 2005 | 01:12 PM
ken93vette's Avatar
ken93vette
Thanks for the info. greatly appreciated.
Ken
Old Sep 2, 2005 | 02:58 PM
darkman5001's Avatar
darkman5001
Check out the Random Technology Cats for sale on TPIS website www.tpis.com. They are very good, as everyone on the forum will agree. It's the best performance cat I have seen yet.
Old Sep 2, 2005 | 04:11 PM
91 black convert's Avatar
91 black convert
Default Summit
You might try Summit Racing. They sell the CATCO brand that are direct replacements. Don't know if they have one for the 93 Vette or not, but they are good pieces at reasonable prices.
Old Sep 2, 2005 | 04:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The Catco from Summit are $55 but not likely to be a direct fit.
My 2000 TPIS catalog does not list cats for Vettes beyond the '91 L98, which are around $215. You might contact TPIS so see if they now have a direct fit for '93 Vette.
Old Sep 2, 2005 | 06:38 PM
bogus's Avatar
bogus
I will be honest, I don't think anyone makes a direct fit for the LT1... they are all cut and weld.
Check Carsound. They flow real good.
Old Sep 2, 2005 | 09:21 PM
88JDO's Avatar
88JDO
Default converter
I have a random technology cat on my 88. Passes emissions with no problem (the pre-cats are gutted)
Old Sep 2, 2005 | 09:50 PM
VMAX451's Avatar
VMAX451
I bought a Catco direct fit for my LT1 a few years back, which really was a direct fit. It was $150, but that was in 2002. While it was made to bolt right up, the bolts on the three bolt flange on the manifold side were not drilled right, I had to enlongate one of the holes so that I could get all three bolts into the manifold. Also, the holes on the other end where the cat-back bolts in were not tapped, so I had to buy bolts/nuts rather than just bolt it in using the stock bolts. Also, the case was a lot smaller than the stocker, not sure if that's good or bad.
Old Sep 2, 2005 | 10:10 PM
gpvette7692's Avatar
gpvette7692
8th Gear
You can order Magnaflow direct fit convertors from Summit racing equipment part numbers MPE-23408 and MPE-23409 for $143.00 each.
Old Sep 3, 2005 | 08:17 AM
91 black convert
Not true. If you read the catalog correctly, they are direct fits and they start at $55. I bought a direct fit for my '91 recently and it cost about $127, as I remember. It went right on with no problems. That doesn't mean that they indeed have a direct fit for the '93, but you can go to their website to find out for sure.
My $0.02
Jim S.
Old Sep 3, 2005 | 02:18 PM
peggysspace@yahoo.co's Avatar
Look at AJ-USA.com see if they have some for it then call me Peggy 913-299-3621
Old Sep 3, 2005 | 02:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I don't think you'll find a direct fit, other than stock. NAPA has good replacement cats in 3" for well under $100. If you pay a muffler shop to fit them you should still be way ahead, money-wise, with a universal replacement type. Also these types are smaller, giving you more working room for changing the fuel filter and other work in those areas.
Old Sep 3, 2005 | 03:03 PM
bogus's Avatar
bogus
Corvette Kid - Apparently, we are wrong... very interesting find! Noted!
Old Sep 3, 2005 | 03:08 PM
Corvette Kid
Damn, first time ever for me, how about you? Good find. And how'd we miss that the first time? I can blame mine on old age....
Old Sep 3, 2005 | 06:59 PM
bogus's Avatar
bogus
I blame mine on being lazy...
To Catalytic Converters?
