Code 24 question
Old Sep 2, 2005 | 01:40 PM
valkryder's Avatar
valkryder
Default Code 24 question
I have had Code 24 for sometime now. What does the vehicle speed sensor do and is it a problem to drive without having taken care of the problem?
Old Sep 2, 2005 | 02:40 PM
CFI-EFI's Avatar
CFI-EFI
The VSS sending the code, is a part of the instrument panel (IP), not the device hanging off the back of your transmission. Basically it tells the ECM the vehicle speed which it uses, primarily, to engage the TCC. Transmission life, due to excess heat, and fuel mileage would be the most noticeable symptoms. There is a trouble shooting chart in your factory service manual to isolate and repair the cause.
RACE ON!!!
Old Sep 2, 2005 | 02:49 PM
valkryder's Avatar
valkryder
Default Speed sensor
So are you saying that once my instrument cluster is repaired all will be ok???
By the way, what is the TCC?
Old Sep 2, 2005 | 03:25 PM
Morley's Avatar
Morley
No, the ECM gets its signal for VSS from the same place as the cluster, not from the cluster itself. You have either a wiring problem between the VSS & ECM or the VSS is bad.
TCC= Torque Converter Control, that is the solenoid that locks/unlocks the torque converter. Not a good thing to run without the converter locked up when it is supposed to be.
Old Sep 2, 2005 | 04:06 PM
valkryder's Avatar
valkryder
Default Code 24
Is there a way, by driving the car, to determine if the TCC is locking and ulocking? The car seems to shift just fine.
Old Sep 2, 2005 | 10:05 PM
CFI-EFI's Avatar
CFI-EFI
Absolutely not. If I was saying that, I'd have said that. I'm saying, "There is a trouble shooting chart in your factory service manual to isolate and repair the cause.". You can save yourself a lot of time and trouble if you utilize it.
TCC = Torque Converter Clutch.
Wrong! It's time to consult the service manual.
RACE ON!!!
To Code 24 question
