a/c compressor shot?
Old Sep 3, 2005 | 01:10 PM
Ras119's Avatar
Ras119
Default a/c compressor shot?
Okay, so the other day under acceleration i noticed a vile buring smell somewhere between wood and a plastic type smell. Something i've never expierenced. No, there was no fire or noticible smoke on anything so I couldnt really pin down the culprit. The next day it smell came back and was followed by warm air from my vents will under full a/c power. Following this was a loud screeching vibration that could be felt through the whole car. Sounded like garbage but was relieved by turning off the a/c. The a/c will return to cold so i am assuming the compressor is not seized, although on visual inspection the front plate seems to be turning rather slow and not at all smoothly. Could this be in fact a pre-seize and signs of an immenent death of the compressor? COuld it simply be a low freon level? I am mostly discounting the low freon level would could be associated to the issue but I can't figure out the buring smell if it wasnt an intermittent seizure. Any thoughts? By the way I have a '90 with the full electronic a/c.
