Code 36
Old Sep 3, 2005 | 02:49 PM
vette40509's Avatar
vette40509
Default Code 36
When a 1987 automatic conv throws a code 36, what is it?? Thanks.
Old Sep 4, 2005 | 12:22 AM
dougd2000's Avatar
dougd2000
6th Gear
have an 88 manual--------code 36 is MAF Burn off Circuit
Old Sep 4, 2005 | 04:14 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
GM says they need to be serviced reguarly but they give no stats.
Old Sep 4, 2005 | 05:13 AM
hngacurv's Avatar
hngacurv
More than likely the relay is bad. Both MAF relays are located behind the battery on the firewall.
Old Sep 4, 2005 | 10:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Read this......... http://members.shaw.ca/corvette86/Code%2036.pdf
Its from my 86 manual but should be identical.
Old Sep 4, 2005 | 10:11 AM
vette40509's Avatar
vette40509
Thanks!
Old Sep 4, 2005 | 12:10 PM
vader86's Avatar
vader86
MAF relays usually, if they arent the culprit then replace the MAF.
Check wiring too.
To Code 36
