It simply is a wonderful day weather-wise. I took the '92 Vert to work for a couple of hours work. It was as good a reason as any to cruise. On the way home, my miles of smiles was interrupted by noticing the "Service ABS" light on the CIC.
I'll be doing a search shortly in FAQ and Tech Tips, but anything quick here I should check first?
The car just got past the 500 mile mark on the engine rebuild, having just got the Mobil 1 replaced a bit over a week ago. It ran great otherwise.
I have had the same problem. Everything that I have read says; check the brake fluid level. I'm going to have mine flushed, I don't know when it was done last. Good Luck I haven't fixed it yet!!!!!!!!
I got a PM to check the brake fluid level, which was full and fine. I took it on a quick run this afternoon, and the 'Servie ABS' light did not come on. I'll have to take it on a longer ride next.
