Rear View Mirror removal
Old Sep 3, 2005 | 05:55 PM
wheelsup's Avatar
wheelsup
Default Rear View Mirror removal
Any tips on removing the entire inside rear view mirror and wires on a 91 Vette.
Old Sep 3, 2005 | 06:01 PM
Morley's Avatar
Morley
Yeah. Don't break the windshield. That metal "shoe" that is bonded to the windshield is a bugger to get off when done right. I've heard of people using heat to get it to let go, never had any luck myself.
Old Sep 3, 2005 | 07:50 PM
wheelsup's Avatar
wheelsup
My mirror is not bonded to the windshield.
Old Sep 3, 2005 | 08:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
On my 86 its just a screw and the wire connector is behind the windshield trim.
Old Sep 3, 2005 | 09:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Remove the set screw and let the mirror hang.
Drop the center of the header trim and open the connector
Remove the mirror wire from the header.
Reattach the header trim.
Old Sep 3, 2005 | 10:07 PM
Sam Lam's Avatar
Sam Lam
65Z01 is "right on" with his comments! Anyone wanting to get the bonded rear view mirror (this is not found on my C4 Vette either), use a razor blade paint scrapper. Slide the blade under the metal dohickey in multiple places and she will just fall off in your hand!
SAM
Old Sep 3, 2005 | 10:30 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
This was just the way I removed mine on 1989.
Old Mar 17, 2025 | 05:24 PM
ka5cdj's Avatar
ka5cdj
3rd Gear
What is the best way to get that connector to unplug??
To Rear View Mirror removal
