Rear Allen Wrench
Old Sep 5, 2005 | 11:50 AM
mikey whipreck's Avatar
mikey whipreck
Default Rear Allen Wrench
1985 L98 A4 with the Dana 36 3.07 rear...
I went to add some differential fluid to the rear on my vette, and I couldn't find an Allen wrench to fit the filter plug. I had some too big and some too small...
Does anyone know what size it takes to unscrew that plug?
Thanks in Advance
Old Sep 5, 2005 | 12:26 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got an '85 D44 but I'll bet it's the same. Mine's a 3/8" allen drive. In a pinch, take a bolt with that size of head on it, lock a couple of nuts together on the bolt then put the bolt head in the plug and turn it out with a wrench on the nut closest to the bolt head.
Old Sep 5, 2005 | 12:35 PM
mikey whipreck
That bolt trick is a pretty good idea. If Sears doesn't have that wrench, that's what I'll probably try. thanks.
Old Sep 5, 2005 | 12:50 PM
Aardwolf's Avatar
Aardwolf
A pipe wrench or channel locks works to.
Old Sep 5, 2005 | 01:22 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
bI usually use a 3/8th socket extension,works well.
Old Sep 5, 2005 | 02:26 PM
Corvette Kid
True for many vehicles but unless yours is different than all the Vette plugs I've dealt with, these are six sided. Something you could do with a more common tool wasn't difficult enough for these cars!
Old Sep 5, 2005 | 03:01 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I ran into the same problem the other day while re-filling the trans in my son's S10. The hex in the plug was huge and I tried the bolt with two nuts trick then but the plug was so tight the nuts kept turning. It was late so I went to Auto Zone and they had a set of 3 sockets with different size hex or allen type heads on them, $7.99 and the big one worked like a charm. They had a set for std. and metric.
Old Sep 5, 2005 | 07:14 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Just what size did "the big one" turn out to be???
Old Sep 5, 2005 | 10:10 PM
Midnight 85
The sizes were 12, 14, & 17. Obviously these are metric. I'm not sure what size mikey needs for the diff. plug.
Old Sep 5, 2005 | 11:47 PM
mikey whipreck
I had a 12MM and 17MM...
12 was too small and 17 was too big
Old Sep 6, 2005 | 08:27 AM
aboatguy's Avatar
aboatguy
I just checked the D36 is the shed and it a 3/8" allen just like my D44.
Sometimes I get frustrated by the mix of metric and standard used on these cars!!!
Mike
Old Sep 6, 2005 | 08:36 AM
mikey whipreck
Mike
Cool, thanks for checking. That's the size I'll pick up then.
Old Sep 6, 2005 | 10:29 AM
Aardwolf's Avatar
Aardwolf
Same here!
To Rear Allen Wrench
