oil pressure: weird behavior
the gages on the '90 are a bit squirrely, so its hard to tell exactly where my oil pressure is. normally, its about 60psi or slightly higher when cold, and when fully warmed up and cruising.
however, something strange has started happening.
symptoms:
1. after spirited driving (ie, fully warmed up), the oil pressure drops approx. 20-30 psi -- just for a second -- then regains previous pressure reading. this occurs immediately after each shift.
2. after decelerating, immediately once idle is attained.
what sorta scared me was tonight. after rowing thru the gears a few times, hitting in the mid-5000 rpms. (the max i've ever hit was 6200 rpms, only did this a few times previously while doing some WOT datalogging), i went to a stop and immediately upon achieving idle speed, the oil pressure dropped so low that the "check gages light" went on for a split second, then oil pressure went back up to normal idle pressure (about 30 psi or so). this never happende before.
there no are strange noises or any loss of power that is noticeable.
is this just an anomaly with HV oil pumps?
the thing is, this minor strangeness is only ocurring now.....about 2,500 miles after my last engine rebuild.
what is causing this?
Didn't run anything over.
As for whether the pick-up was welded on, I'm sure it was but I'll have to check with Bill tomorrow, first thing in the morning.
Good luck with getting it all sorted out.
Mike
RACE ON!!!
RACE ON!!!
i didn't have to even go that far. this morning i surely discovered the cause.....oil level was about 1/2 of what it should have been, approx. 2.5 qts low. simple math reveals this consumption ocurred in just 1,450 miles of driving. a good deal of WOT blasts 90% TPS @ 5800-6200 rpms after the first 500 miles, so its not like i babied the living daylights out of it
this consumption is obviously high. 2 things i will consider is the fact that its a fresh rebuild (2,400 miles since then), and the pistons are forged. oh.....and the top 2 rings are 1/16" (although i don;t know how definitive oil use is regarding thinner rings, in an L98). i have yet to get the spec sheet from the machine shop, no doubt ring end gap clearance is a bit loose on purpose which is fine by me.
i will immediately begin a program of oil monitoring, and note any decreases over time. its too early to tell, but let's hope the consumption rate will decrease somewhat. a certain (higher) level of blow-by is probably normal with forged pistons, and i can accept that. if i end up soemwhere in the vicinity of 1 qt every 1,000 miles consumption, i can live with that.
if i'm off-base with any of my logic, please correct me. and i don't want anyone to think i've got half a brain, much of this is something i just learned from a fellow CF member
Mike
Since the pump isn't the issue, I think I'll just leave it in.
however, since i might be looking at a possible lifetime of oil consumption, its just a matter of how much....yet to be determined....
and whether its acceptable, or a problem. hopefully its not a "problem", that would indeed suck
BTW, mine takes 12 qts of oil on every oil change (canton pan, accusump, mocal oil cooler and a lot of -10 hose), and I change it before and after every event I run. It's starting to become an expensive situation.
Mike
