383 forged short block
Old Sep 6, 2005 | 04:32 PM
kpforce1's Avatar
kpforce1
Default 383 forged short block
I'm getting a 383 forged short block. I found one for $2600 w/a 1 year unlimited milage warranty. Sounds good to me... i know a few others on here have bought the non forged versoin from this place and were more than happy with it. Are there any other places in this price range that I could look at for compairison? Thanks
Old Sep 6, 2005 | 04:41 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Who are they and what is this shop's definition of a "forged short block"?
Larry
code5coupe
Old Sep 6, 2005 | 06:23 PM
FD2BLK's Avatar
FD2BLK
I have no dealings with any of these companies but here are a few plus there is always Jegs and Summit
http://golensengineservice.com/html/...rt_blocks.html
http://www.revolutionaryperformance....t%20blocks.htm
http://www.sdpc2000.com/catalog/514/...e-Assembly.htm
http://www.crateengine.net/350383f.html
http://www.theengineshop.com/content/pg09.pdf#search='383%20short%20blocks'
Old Sep 6, 2005 | 07:00 PM
flatlne's Avatar
flatlne
Chad at Golen is a good guy and alot of help even after the sale.I have a 350 forged in my 1990 IROC with a 200 shot on it
Old Sep 7, 2005 | 01:40 AM
kpforce1's Avatar
kpforce1
code5coupe
This is the shop
Their definition of a forged 383 is:
seasoned 4-bolt block
forged 4340 crank
forged 4340 H beam rods
forged KB pistons
New Cleveite 77 Rod and Main Bearings
New Speed Pro performance rings
New Poineer Flexplate
New Proformance Products Ballancer
New ARP Main Bolts Istalled
New Clevite Cam Bearing Set
everything balanced
Old Sep 7, 2005 | 10:21 AM
Vic'89's Avatar
Vic'89
Originally Posted by kpforce1
This is the shop
forged 4340 crank
forged KB pistons
everything balanced
What size are the rods ? You want 5.7" or bigger.
Vic
Old Sep 7, 2005 | 10:46 AM
rocco16's Avatar
rocco16
[QUOTE=kpforce1seasoned 4-bolt block
forged 4340 crank
forged KB pistons
everything balanced[/QUOTE]
Assuming the crank and rods are premium brands, those sound like some good parts. If they are assembled correctly it could be a solid engine....myabe even overkill. And that's always a good thing.
Larry
code5coupe
Old Sep 7, 2005 | 11:25 AM
kpforce1's Avatar
kpforce1
Larry
code5coupe
I'm pretty sure they will be using part number ESP-B12008030 from summit racing. I'm finding out for sure today. I'm also going to tell him I don't want a balancer, flexplate, or any "extra" stuff. Just the seasoned block with the rotating assem., cam bearings, and etc installed ready for me to drop it in the beast. As far as overkill goes... Sh*t, i would feel safer knowing that I am not going to have my pistons comming apart at 6k+ RPM's or a rod acting as a hole punch on my block.
The rods are 5.7" Vic'89
One question I do have is about Cam/Rod/crank clearance. I know in a 350 you don't have to worry about the cam grind and stroke... but on a 383 and above you do because of the increased stroke? This is the Cam Grind i have. With 5.7" rods and a 3.75" stroke do I have to worry about clearance issues?
I'll keep you all updated on the cost because I think its a pretty good deal for what it is... and have a warranty. Thanks again
Race on!
Old Sep 7, 2005 | 11:47 AM
CFI-EFI's Avatar
CFI-EFI
The length of the rod has little or nothing to do with camshaft clearance. It all depends on the profile of the rods being used. Even with stock rods, the bolt heads can be ground to clear. Since this is "a 383 forged short block", I would expect that any and all clearancing has been done. ASK!. Then, when you get it, CHECK!
RACE ON!!!
Old Sep 7, 2005 | 12:02 PM
kpforce1's Avatar
kpforce1
RACE ON!!!
Learn something every day.... just didn't understand the clearance issues on a 383. Thanks CFI!
To 383 forged short block
