Power Lose after SR install?
Old Sep 6, 2005 | 05:35 PM
SDS Photography's Avatar
SDS Photography
Default Power Lose after SR install?
am I imagining things or did I lose a lot of power by just installing a ported SR? I thought I would lose some but it feels like I lost a good bit. Do I need to go ahead and do a cam swap?
Old Sep 6, 2005 | 05:39 PM
vader86's Avatar
vader86
You lost some low end, yes. You shouldve done the cam swap at the same time, and had it tuned.
Nathan Plemons's Avatar
Nathan Plemons
On an otherwise stock engine?
You probably lost most of the low end power gained by the "tuned port" technology that you had. If there was any power to be had on the upper end your cam either can't take advantage of the extra airflow or the tune is so far off now that it's not even close to running right.
It's all about picking the right combination of parts.
Old Sep 6, 2005 | 05:40 PM
SDS Photography
so what would be a good cam choice?
BTW this is my DD so I need something middle of the road
Old Sep 6, 2005 | 05:42 PM
vader86's Avatar
vader86
accel 74219
Old Sep 6, 2005 | 05:48 PM
SDS Photography
would that be better than a 219?
Old Sep 6, 2005 | 05:52 PM
Nathan Plemons
I think that is the 219, just not ground by LPE maybe.
Old Sep 6, 2005 | 10:03 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
On a DD stock engine,the factory TPI will provide the most SOTP power off the line and passing.I even tried larger tube runners and SLP's tubes and found it felt sluggish off the line and low speed driving.I put the factory TPI back on and it felt great off the line and had better throttle response.Thats due to the engine being stock internally.
Sounds like you should have a cam and headers to complete the SR set up but even with that cam,the car wont feel as fast off the line but once you start to hit 2,000 rpms or so its gonna start pulling harder,making decent torque and power across the rpm band.
Does your car now pull any harder in the mid 2000 range and up?If so thats the SR beginning to work.
You may even need a tune/chip to make things run better with the cam change and etc.
Just remember,on a stock engine,intake mods/larger TB's, and parts wont make the car feel any faster.You would need real track times to see if there was any benefits.
Old Sep 6, 2005 | 10:05 PM
Aggravated4life
One more thing,whats the rear gear ratio of your car?If its less than 3.07 -3.42 than those kind of mods may benefit with a gear change.If you have the automatic transmission,the torque converter can be changed to increase the offline performance as well to a higher stall speed over stock.
Old Sep 6, 2005 | 10:11 PM
Red Tornado's Avatar
Red Tornado
Bill's86 is right. I have the full SR intake, as well as an Accel #74219 cam and aftermarket fully CNC'd heads. I can tell you this package WAKES the hell out of the stock L98 in a major way, and you will FLY as soon as you hit mid 2000-rpms -- straight on thru to the upper 5,000 rpms. This is a helluva blast.....alot of money but daily grins from ear to ear, ball-bearing' guaranteed.
I wanted something real and this is definitely it. No need to wonder if there's SOTP improvment by comparing numbers, shmumbers. You wont need a track or dyno to make calculations. This is a no-nonsense package that WORKS, throws you back and has wonderful power, and major improvment over stock TPI across the band, in every way. By the way, I feel more power - not less - from a dead stop vs. factory setup.
Old Sep 6, 2005 | 10:30 PM
Pete K's Avatar
Pete K
What he said.
Old Sep 6, 2005 | 10:38 PM
SDS Photography
well now i know what i need
thanks guys
Old Sep 6, 2005 | 11:08 PM
vader86's Avatar
vader86
it is the 219
Old Sep 7, 2005 | 12:11 AM
Red Tornado
vader is right.
LPE/Accel #74219 cam:
http://www.lingenfelter.com/Merchant...Category_Code=
You might find this little tidbit useful, on the subject of your question:
http://home.adelphia.net/~lebeter/ac...ap/page2-2.htm
Old Sep 7, 2005 | 10:49 AM
jack the stripper's Avatar
jack the stripper
hey hot-rod, what kind of aftermarket heads did you use?
Old Sep 7, 2005 | 11:31 AM
Red Tornado
jack, visit TPIS here:http://tpis.com/
click on "engine R&D"
click on "engine components"
click on "air flow research heads"
p/n 500-525
actual measurments of chambers turned out to be 56cc, not 54cc. 100% CNC'd intake/exhaust, these heads match AFR's old 190cc version (no longer sold), but are 187cc, the flow is right with AFR's own competition ported heads, I got 7/16" studs. I paid $100 less, price included shipping.
not cheap by any means, but I wasn't interested in ever buying another set of heads again.
these were looked over & tested by the machine shop, airtight, no quality problems, were untouched and installed right out of the box.
the machine shop was astounded as to why a customer would buy such "monster heads for a street application", i told them the answer is obvious, i don't like import punks ruining our streets they tacitly agreed
Old Sep 7, 2005 | 11:55 AM
kopbet89c4's Avatar
kopbet89c4
I know I might have lost some low end tire spinning grunt, but at least the performance of my L98 is similar to an LT1 now, just without the optispark.
To Power Lose after SR install?
