LT1 Temperature
Old Sep 8, 2005 | 03:11 PM
bvs3's Avatar
bvs3
Default LT1 Temperature
My 1992 LT1 seems to be running hotter.
The temperatures are running between 195 and 210 (depending on wheather I'm cruising the highway or driving in traffic) and I've seen it hit 215/220 sitting in traffic.
I'm not positive, because I never paid close attention, but It seems like the car ran quite a bit cooler when I first got it 5 years ago. I seem to remember it running in the 180-190 range.
I'm just worried my car might be running too hot. Am I crazy here? Or do I possibly have a problem I should look into?
Old Sep 8, 2005 | 03:24 PM
dchildress's Avatar
dchildress
You are in the normal range. My 94 6speed will hit 230 in traffic on a 85 degree day. If I start it and go right to the highway my temps stay around 190. If I get in traffic and get it up to 230 and get back on the e-way the temp will come back down to 200 and stay there for 15 miles. Have you flushed your cooling system? Checked for crap in your radiator?
Old Sep 8, 2005 | 03:30 PM
bvs3's Avatar
bvs3
I know the previous owner put a 180 degree thermostat in, so maybe that's why I expected lower temps.
I should check for stuff blocking hte radiator. I know c4's are famous for sucking stuff up there. But I also hear it's a pain to check and clean.
Old Sep 8, 2005 | 08:02 PM
Zix's Avatar
Zix
Your temps are good, nothing to worry about. You can of course take a look and see if there is any debris caught in the radiator...certianly won't hurt! I did notice mine was running hotter recently and when I got under the car there was a plastic shopping bacg covering almost the entire radiator!! BUt honestly, if you are hitting a max of 220 when sitting in traffic you really have nothing to worry about...come down to Phoenix when it's 115 out and sit in traffic and watch your temps!!
Old Sep 8, 2005 | 08:14 PM
bvs3's Avatar
bvs3
so, just out of curiosity, what's the upper coolant temp threshold for the LT1 engine?
Old Sep 8, 2005 | 08:21 PM
Zix's Avatar
Zix
I pull over when I see about 238 coolant, but the only time I saw that was when I had the bag covering my radiator...
Old Sep 8, 2005 | 09:02 PM
CFI-EFI's Avatar
CFI-EFI
Lower than what? The 180° stat is stock for your car. Remember, the stat has nothing to do with how hot it will run, only how cool it can run.
RACE ON!!!
Old Sep 8, 2005 | 09:28 PM
c4cruiser's Avatar
c4cruiser
Your temps are fine!! The stock stat for a 92 is IIRC is a 195 'stat. the temp rating on a thermostat is that tempeature when the 'stat goes fully open. So even if you have a 180 degree stat in the car, temps can go much higher.
Ambient air temps will cause somewhat higher coolant temps, but I wouldn't worry until you see consistent 238-245 temps. Turning the A/C on forces the secondary fan to run and that should lower the coolant temps somewhat. Of course driving in stop and go traffic on a hot day will cause the temps to go up.
The primary fan goes on when the coolant temp hits 228 degrees and goes off when the temps drop 41 degrees.
The secondary fan will come on at around 234 and go off when the temps drop about 41 degrees. If the oil temp goes above 235, the secondary fan starts and goes off when the oil temp drops 36 degrees.
Old Sep 9, 2005 | 08:11 AM
Atok's Avatar
Atok
My '95 runs at 188-189 on the highway in 75 - 85 degree weather. Stock 180 degree thermo. At idle it runs hotter.
Old Sep 9, 2005 | 08:14 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Your temps are good. Mine will reach 210 in bumber-to-bumper traffic (no A/C fans engaged) but will quickly settle to the 190 degree range when I get up to crusing speed or sustaind speeds above 45 mph on backroads.
Old Sep 9, 2005 | 11:59 AM
CFI-EFI's Avatar
CFI-EFI
Is that correct? I thought 1992 was the first year of the LT1. I thought L98s came with 195° thermostats and that the reverse coolant flow, Gen II, engines were equipped with 180° stats.
RACE ON!!!
Old Sep 9, 2005 | 11:41 PM
MetalVette's Avatar
MetalVette
your good, I just had my radiator rotted out, it had 25% blockage at 90, 000 miles, brought temps down to 192. Cost $250, but worth it. I heard 245 is the danger zone, especially for an LT4
Old Sep 10, 2005 | 01:39 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Where's bogus? Actually your temps are right in check. You've probably just been reading too much garbage on the forum about 160 degree engines and noticed yours.
If the fans don't drop the temp like a rock, or it heads over 230, then it's time to start scratching your head.
Old Sep 12, 2005 | 10:57 PM
bvs3's Avatar
bvs3
Hmm... turning AC on actually makes my temps rise quite a bit. I was running a steady 216 or so on an 80 mile drive (freeway) on friday. Which is MUCH higher than it normally runs.
I'll probably try the get the radiator cleaned when I store it this winter.
Old Sep 12, 2005 | 11:22 PM
FDAMFA's Avatar
FDAMFA
My 92 runs around 210 in traffic, however when you get it moving in traffic instead of stop and go traffic it settles in around 190 or so. It ran 234 once when i too got a plastic bag stuck on my radiator
To LT1 Temperature
