brake problem
Old Sep 9, 2005 | 11:20 AM
Billy Stargazer's Avatar
Billy Stargazer
Default brake problem
I have noticed that my brake pedal goes pretty far down to the floor. I have also noticed that there is a sound of air escaping when I depress the pedal. There does seem to be a slight spongyness to the pedal also. Any guess to what my problem might be? Am I right in thinking the power assist? Any help would be appreciated.
Old Sep 9, 2005 | 11:41 AM
Gary04Z06's Avatar
Gary04Z06
Make sure you have good brake fluid, not black, in there. Check all the lines at the master cyclinder for leaks, etc. Sounds like it might be the power asst.
Old Sep 9, 2005 | 01:47 PM
Hotred94's Avatar
Hotred94
There is a vacuum line that runs to a plunger type fitting on your brake pedal, has to do with cruise control, that is leaking and that is the hiss you are hearing.
Old Sep 9, 2005 | 02:01 PM
vader86's Avatar
vader86
Master Cylinder most likely.
Old Sep 9, 2005 | 02:21 PM
FDAMFA's Avatar
FDAMFA
Old Sep 9, 2005 | 02:45 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like your brake master cylinder's gone biznoobies up to me, too.
To brake problem
