Performance Heads
Old Sep 10, 2005 | 08:36 AM
Legion21's Avatar
Legion21
Default Performance Heads
Alright, I'm getting together a plan to do a Head/Cam swap for my 96 LT1. Who makes performance Heads for the LT1, here is a list of the currnet companies I know of.
AFR
Edelbrock
Trickflow
GMPP
Lloyd Elliot
Advanced Induction
I'm not loooking for a debate on who's the best, just other manufacturers/machinists that I may not know about, and I will do my own investigating into each of them.
Thanks, Greg
Old Sep 10, 2005 | 11:05 AM
tjwong's Avatar
tjwong
AFR
Edelbrock
Trickflow
GMPP
Lloyd Elliot
Advanced Induction
Thanks, Greg
AFR makes great heads.....but they are about 4 months wait to get them. Edelbrock are OK at best their runner sizes are rather anemic. If you are bolting them onto a stock engine with a very mild cam, they will work better than stock.
GMPP only offers LT4 replacement heads which are good for a mild build up. Trick Flow makes a very good LT1 head. But the problem is that their combustion chamber size is 62cc which would drop your static compression ratio down a point, this isn't great for performance. However if you are building a 383 or a hot 350 then this is the way to go. You can get these heads bare and have one of the above porting services port them to 200cc or more. These heads will flow as well as any LT1 AFR head with porting.
Lloyd Elliot and AI are good head porters. Another is TEA or Total Engine Airflow, CNC Heads is another example of a great porting service.
At this time my advice would be to have one of the porting services above to port either your stock castings of a set of new LT4 castings. With the later LT4 heads you would need to replace the intake manifold as well. Lloyd does excellent work, I have had personal experience with his work so I can vouch for it, and his prices are very reasonable. The others are excellent as well.
Old Sep 10, 2005 | 11:30 AM
bacardioil's Avatar
bacardioil
talk to ( harold ) at port pros. in tx. this man will give you a set of heads you will not believe. tell him gene told you to call him. you wont be sorry.
Old Sep 10, 2005 | 12:45 PM
STL94LT1's Avatar
STL94LT1
Pete at CNC Cylinder heads did a great job on my heads/cam combination.
Old Sep 10, 2005 | 12:47 PM
hippy's Avatar
hippy
Not sure if this is relevant for LT motors but I went with Tricks on my L98 and used the 1094 head gasket/shim. This gasket is only .015" compared to .039/.041 for a std head gasket. I guessed that the volume for the .015 to be in the neighborhood of 3.2cc vs 9cc for a .041. So with a 62+3.2cc=65.2cc vs 58+9=67cc for a L98 set up I figure that you can get away with the larger head chamber.
P.S. Trickflows are junk.
Old Sep 10, 2005 | 08:27 PM
Performance nut's Avatar
Performance nut
oh, we arent going to start that again are we?
Old Sep 10, 2005 | 10:04 PM
MYCoupe's Avatar
MYCoupe
...At this time my advice would be to have one of the porting services above to port either your stock castings of a set of new LT4 castings. With the later LT4 heads you would need to replace the intake manifold as well. Lloyd does excellent work, I have had personal experience with his work so I can vouch for it, and his prices are very reasonable. The others are excellent as well.
This is the best bang for the buck. You should be able to get your heads ported with a matching camshaft for well under $2k. I'm going to have Lloyd Elliott port my heads in the spring. I've heard nothing but good comments about him and he's answered all my questions right away.
Old Sep 11, 2005 | 12:02 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Thats what I now have, Cartek did my top end.
Old Sep 11, 2005 | 12:29 AM
cv67's Avatar
cv67
St. Jude Donor '05
All cylinder heads are junk
Old Sep 11, 2005 | 12:45 AM
Red Tornado's Avatar
Red Tornado
Old Sep 11, 2005 | 10:49 AM
mackeyred96
There is MUCH room for improvement
Old Sep 11, 2005 | 09:32 PM
LT4POWR's Avatar
LT4POWR
that's my top three
To Performance Heads
