Calling timing experts
Old Sep 12, 2005 | 08:20 AM
dave_85's Avatar
dave_85
Default Calling timing experts
I am chasing some knock counts (again) and I forgot if the table included the base timing or not. So I figured I’d measure it. I had my scanner hooked up and I had 40 degrees at idle. I should have had 26. I unplugged the scanner and now I have 26 degrees. Does anyone know why the ECM added advance when the scanner was connected?
If you have the scanner connected is timing advance added anywhere else.
Old Sep 12, 2005 | 02:46 PM
gbody5's Avatar
gbody5
How are you measuring timing advance? Did the scanner show 40 degrees at idle?
Old Sep 12, 2005 | 02:53 PM
dave_85's Avatar
dave_85
I measured it with an advance timing light. The kind that has a dial on it that you turn to get the strobe to show 0 degrees on the balancer, then you read the advance off the dial.
I was not scanning the car I just had the ALDL cable hooked up. When I removed the 10k resistor between port A and B the timing dropped to what was programmed in the chip.
Old Sep 12, 2005 | 03:09 PM
gbody5's Avatar
gbody5
Interesting. I would not think just hooking up a scanner would affect timing like that, unless it was in some sort of diag mode.
I know when I first begin to scan my RPM's will rise for a second or two, then settle back down to normal, like the timing has temporarilly jumped up, but never stayed that way.
What does the scanner read at idle? Should be total timing in the chip, the ECM does the addition (or subtraction if you will) of the base vs. total.
Old Sep 12, 2005 | 08:14 PM
Bluevette85's Avatar
Bluevette85
I can remove the 10k ohm resistor once Datamaster or TunerproRT connect with the ecm. Leaving the resistor in place will add some timing. Also, make sure you're in closed loop when looking at the timing numbers.
Old Sep 13, 2005 | 02:19 AM
Morley's Avatar
Morley
When in ALDL mode the 870 ECM fixes idle at 1k RPM and adds in timing. Just another little quirk of the 870.
Old Sep 13, 2005 | 08:48 AM
dave_85's Avatar
dave_85
Sorry I forgot to include that I have the 165 ECM.
Old Sep 13, 2005 | 08:13 PM
Bluevette85
My response is for the 165 ecm because I converted to it from the 870.
Old Sep 14, 2005 | 10:12 AM
dave_85's Avatar
dave_85
Cool, so you use the 10k to connect then remove it during a scan. I will give it a try.
To Calling timing experts
