Cruise Control
Old Sep 13, 2005 | 10:26 PM
85VetteBoy's Avatar
85VetteBoy
Default Cruise Control
Hey all -- 85 Corvette.. and the cruise does nothing. On my other cars.. the first place to look is usually the brake switch.. I did a quick look under the brake and didn't see it. Can you give me an idea of what to start checking? It does nothing.
jp
Old Sep 14, 2005 | 09:49 AM
rick lambert's Avatar
rick lambert
Seems to me alot of guys have corrected this by repairing or replacing the vacumn line to the cruise control.
Old Sep 14, 2005 | 10:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 manual.................................. ........
http://members.shaw.ca/agent86/Cruise%20Control.pdf
Old Sep 14, 2005 | 11:26 AM
85VetteBoy's Avatar
85VetteBoy
Default Thanks
I really appreciate it. The vacuum lines look fine. I would consider something like that if the cruise light lit up.. but, it does absolutely nothing
jp
Old Sep 14, 2005 | 01:58 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you disconnect cruize cable from the throttle you can jumper signals to the controller (located over the battery) at idle to test the controller. With the connector open you can also test signals from the multi-function sw on the steering column.
If you drop me an e-mail I can shoot off some pics of the two relavent wiring pages from my '85 Shop Manual and get them to you by return mail.
Old Sep 14, 2005 | 02:17 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
jp
I always check the fuse first
If that is fine does your digital dash work properly bc the cruise goes through it, then relay
if the light on the dash doesnt come on sounds electrical to me and not vacuum related
just my .02
To Cruise Control
