Code 41-HUH
Old Sep 16, 2005 | 09:44 AM
AFogleman's Avatar
AFogleman
Default Code 41-HUH
What exactly is this code.Thanks,
Old Sep 16, 2005 | 10:29 AM
VAHROOM's Avatar
VAHROOM
Default I "think" it is
I think it is the EST circuit. Might be indicative of bad distributor module, some one disconnecting and reconnecting the EST wire to set timing or something like that.
Is it a constant (hard) code? Is the SES light lit all the time?
Old Sep 16, 2005 | 11:04 AM
AFogleman's Avatar
AFogleman
It is the est code.And yes the light comes on instantly most of the time.But this code doesn't always show.I ran the codes sitting and driving yesterday.Will an eratic idle caude this code to set.Also has a 25.MAT.
Old Sep 16, 2005 | 06:41 PM
AFogleman's Avatar
AFogleman
Where is the disributor module,and is it called something else?
Old Sep 16, 2005 | 07:21 PM
CFI-EFI's Avatar
CFI-EFI
Poor performance doesn't cause codes to be set. Performance BECOMES poor because of a malfunction. Many times that malfunction will cause a code to be set. Remember, when a given device sends a code, it doesn't necessarily mean that the sensor is bad. Don't shoot the messenger. Trouble shoot the code as per the chart(s) in your factory service manual.
RACE ON!!!
Old Sep 16, 2005 | 07:50 PM
AFogleman's Avatar
AFogleman
How many times have you said that?I know!What I'm saying is can the poor idle cause other sensors(Messengers)to malfunction etc.
Old Sep 16, 2005 | 07:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 manual
http://members.shaw.ca/corvette86/Code%2025.pdf
http://members.shaw.ca/corvette86/Code%2041.pdf
Old Sep 16, 2005 | 08:06 PM
CFI-EFI's Avatar
CFI-EFI
Apparently, not enough times.
It is entirely possible that a performance problem has more than one cause. And it IS possible that out of perameter conditions can cause other (temp, for instance) problems to occure. Systematic trouble shooting should lead to the discovery and allow for the corrections for ALL the faults.
One more time, for good measure. Remember, when a given device sends a code, it doesn't necessarily mean that the sensor is bad. Don't shoot the messenger. Trouble shoot the code as per the chart(s) in your factory service manual.
RACE ON!!!
Old Sep 16, 2005 | 08:11 PM
AFogleman's Avatar
AFogleman
Thanks for your advice guys.I'm still new to all of this.
To Code 41-HUH
