Antenna Booster Ground Plane Kit
OR, does anyone have a diagram/Picture of what this looked like?
HE
HE
HE
HE
When my gas tank was replaced the tech left them hanging. I repositioned them as best I could to the fsm picture.
My radio worked about the same b4 and after so I don't think it's very critical where they go. Just spread em out a bit.
Cheers, am awaiting a picture or diagram from LT1for fun (Or anyone else). I think I have the picture in my mind tho and going by THAT; I see no reason that I can't make one (May have to calculate the electrical length by dividing the 'main elements' x 30,000 - If antenna making memories serve correct) : THIS should give me the 1/4 wavelength of the frequency (Mid dial)
ALSO, (& I'll post this as a separate thread I think) I've just spent TWO DAYS looking for the 'missing' male-male plug I ASSUMED to be there to join the female end of the antenna coaxial cable, to the female end of the coax coming from the antenna - GUESS WHAT?! I pushed one female end INTO the other female end; and it CLIPS INSIDE each other!
GRRRRRRRRRRRRR!!!!!!!!
hehe...Would also help to be able to REMEMBER when one takes apart the damned plugs!
Trust Chev to come up with something totally WEIRD!!!!!*NOTE; After not being able to RELIABLY recall the old math mentioned above; I found a different means of calculating the dimentions needed, thus (For anyone interested):
One Wavelength, in feet = 984 / Frequency in Megahertz (MHz)
example:
CB Channel 40 uses the frequency 27.405MHz.
One Wavelength for 27.405, 35.906 Feet = 984 / 27.405
Incidentally, If I can work out how to post a pic here, I'll do so showing the weird looking ground plane that I made, using 4 x 1/8th wavelength reflectors...
Last edited by smacko; Sep 20, 2005 at 08:37 AM. Reason: Ammendment to calculation method
Last edited by smacko; Oct 2, 2005 at 02:04 AM. Reason: Changed URL for photo link
on any performance gains, when I finally get my car back on the road (Has been 'offline' for months awaiting new injectors and because I STUPIDLY chose to polish everything alloy, myself!) ehhe
