'95 Radiator Removal
Old Sep 17, 2005 | 02:18 PM
cajuncruiser's Avatar
cajuncruiser
3rd Gear
Default '95 Radiator Removal
Is there an easy way to remove the 6 screws in the front connecting the upper shroud to the lower shroud?
Old Nov 21, 2005 | 09:40 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Not really. I used a 1/4" ratchet, with an extension, and a swivel socket. I think I came in from under the frame, on the sides. To get the screws back in, I tore off a small piece of paper, a little bigger than the screw head, and put it over the screw head, then pushed it into the socket. This keeps the screw tight in the socket, while you guide it back into the hole. You will never get them in the holes with your fingers. Good luck, and be patient.
Old Nov 22, 2005 | 06:16 AM
bad-zr1's Avatar
bad-zr1
When you put them back in just remove the clips from the panel and put them on the other one. Now you can put the screws in from the radiator side. Much easier.
Jim
To '95 Radiator Removal
