Help...service ASR??
Old Sep 17, 2005 | 05:51 PM
Ray Foy's Avatar
Ray Foy
3rd Gear
Default Help...service ASR??
1992 corvette...every so often after I drive for a few Minutes the service ASR light comes on, The light stays on until i turn off the car. I have checked the service manual and everything seems so complicated when I read it...does anyone know any tips to help me understand... what i should do or how to fix it...i appreciate your answers
Thanks,
Ray
Old Sep 17, 2005 | 06:13 PM
jabez's Avatar
jabez
Check for codes.
Old Sep 17, 2005 | 07:07 PM
TM-Z06's Avatar
TM-Z06
Check your brake fluid....make sure your not low.
Old Sep 18, 2005 | 08:53 AM
cavu's Avatar
cavu
This has happened to me before. The ASR relies on speed sensors for in put, one of them may be intermittent. The problem is, on these cars the wheel speed sensor is part of the wheel hub and has to be replaced as a unit. Very expensive. Someone has posted a way to replace it much cheaper with a Fiebird Hub, with minor modifications.
To Help...service ASR??
