Curious, oil change without filter change
Old Sep 17, 2005 | 10:19 PM
L98Corvette's Avatar
L98Corvette
Default Curious, oil change without filter change
Hey guys, just something i was wondering and for my information, if you changed oil in an L98 and you didnt change the oil filter, how many quarts do you put back in?
Old Sep 17, 2005 | 10:31 PM
vader86's Avatar
vader86
4, then check the oil level, add a little if necessary.
Old Sep 17, 2005 | 10:34 PM
L98Corvette
Thanks Vader
Old Sep 18, 2005 | 08:23 AM
fnseeker's Avatar
fnseeker
Default Your kidding right?
Why would you consider changing oil with out changing the filter?
Old Sep 18, 2005 | 08:38 AM
jshyman's Avatar
jshyman
I think of it as taking a shower when you are hot and sweaty and putting back on old underware .
mudslide's Avatar
mudslide
Default filter
If you go through the trouble to jack it up and put the stands under it throw the filter away and ad 5 qts.
Old Sep 18, 2005 | 09:07 AM
93 ragtop's Avatar
93 ragtop
I always change my filter when changing the oil but the reason you can get away with doing it every other change is this. Oil is designed to suspend the carbon it accumulates in the oil. When you drain 80-90% of the oil out you are removing the most of the carbon. It is assumed the filter still has enough life left in it to go another round. That is why most manufactures only recommend filter change every other oil change.
To Curious, oil change without filter change
