Vette stumbles on acceleration
Old Sep 18, 2005 | 09:49 AM
Biff Buyer's Avatar
Biff Buyer
Default Vette stumbles on acceleration
My 85 corvette is all stock except for the entirely new ignition and fuel filter. When I take off or try to pass someone, it'll chug and stumble and even somtimes pop. I defiently notice a pattern though. It stumbles either when its cold, or it stumbles because it has been running for a bit. I dont know which one. It straightens out after its been running a while. When it chugs, it shifts at high hard RPM's. After the engine has been running and warms up, it'll shift at low and smooth RPM's, and runs great. I spose this could be my idle air control, vaccum leak, o2 sensor, maybe my mass airflow sensor, fuel delivery... I dont know. I just adjusted my timing and my TPS. I hooked a fuel pressure gauge up to it at cold idle, its at about 26 psi. Any advice is appreciated.
Old Sep 19, 2005 | 08:44 PM
Biff Buyer's Avatar
Biff Buyer
this doesnt trip any sensors though.
Old Sep 19, 2005 | 10:03 PM
mikey whipreck's Avatar
mikey whipreck
Isn't fuel PSI supposed to be 40 when you first turn the key?
http://forums.corvetteforum.com/show...re&forum_id=48
Old Sep 19, 2005 | 10:23 PM
Biff Buyer's Avatar
Biff Buyer
Thats what it says in my haynes book. This weekend im changing the fuel pressure regulator. I know the fuel pumps are easy to change in a C4, but id hate to bust the 20 year old fuel level float or somthing like that while yanking it out.
Old Sep 19, 2005 | 10:46 PM
Biff Buyer's Avatar
Biff Buyer
ill drive and the throw the car in neutral, it seems alright when i rev it up. The idle is alright except for some lobing and changes in rpm.
Old Sep 20, 2005 | 10:36 PM
viii's Avatar
viii
my 85 chugged a bit on acceleration before when cold (open loop I believe) fuel pressure was 28-29 while running. I intalled a holley adjustable fuel pressure regulator from jegs, increased the pressure to 38 and this performance problem went away.
Old Sep 21, 2005 | 07:46 AM
Biff Buyer's Avatar
Biff Buyer
great, thanks
Old Sep 23, 2005 | 09:01 PM
Biff Buyer's Avatar
Biff Buyer
so i was changing my trans filter and fluid and i had my hood up when i noticed a little rubber hose just limply laying on my valve covers. Turned out it was a vaccum line that went under my throttle body. . It cleaned up a bit, still chigs and stumbles though. Im gunna go ahead and change my vaccum valves and lines anyways.
Old Sep 23, 2005 | 11:57 PM
Cherry6speed's Avatar
Cherry6speed
Have you checked the voltage on your TPS as you move the throttle? Look for a steady increase in voltage. When the TPS fails, the voltage will jump around and will send an erratic signal to the ECM. This will show up as a stumble, particularily off idle. Ask me how I know
Old Sep 23, 2005 | 11:58 PM
Biff Buyer's Avatar
Biff Buyer
Yea, i just stuck some nails in the terminal. got it set exactly between the standerds. so thats set.
Old Sep 24, 2005 | 12:05 AM
Cherry6speed
What voltage did you set it at? and did you check to see if the voltage increases at a constant rate or does it jump around? When mine failed, it would show an erratic reading from high to low as you increased the throttle. Oh well, just a thought, it helped my problem as you described.
Old Sep 24, 2005 | 10:48 AM
Biff Buyer's Avatar
Biff Buyer
My sensor is steady. I just set my timing too. I had a problem like this before, turned out the drain hole by my gas cap was plugged. Water would set in there and seep into my gas tank. Flushed it out with a garden hose.
Old Sep 27, 2005 | 09:03 PM
Biff Buyer's Avatar
Biff Buyer
A few days I noticed that when i got to fill my gas tank, when I take my cap off i can hear a hisssing (equalization of pressure). Problem solved when I unscrew my gas cap. It runs great when i do. I cant tell if its positive or negative pressure. Anyone know what the problem is? Im gunna take that big round thing that sits in my front driver side corner of the engine compartment under the light kinda, and clean that out.
To Vette stumbles on acceleration
