Front end rebuild
Old Sep 18, 2005 | 08:14 PM
onetrackmind's Avatar
onetrackmind
Default Front end rebuild
Started out putting in the poly bushings on the front end on friday, I ended up changing the shocks and upper and lower ball joints, also painted the brake calipers while I was at it. I am not done on the passengers side yet, but here are some before and after pics. I think it looks pretty good aside from the rusty rotors. It should drive like a new car now. I installed new shocks and poly bushings on the rear in May.
Before:
After:
Old Sep 18, 2005 | 08:39 PM
onetrackmind
Sorry the pictures are so large, I am not sure how to change that while using my kodak program.
Old Sep 18, 2005 | 09:50 PM
onetrackmind
I resized the pics, how she look?
Old Sep 18, 2005 | 09:54 PM
87vette's Avatar
87vette
Looks great ! I cleaned up my front end and rear end myself pretty good. I need to get new bushings though. I'm waiting for my bilsteins to arrive and will put them on this coming weekend.
Old Sep 18, 2005 | 10:23 PM
quiksilver458's Avatar
quiksilver458
looks sharp! i will be doing that soon as well!!
Old Sep 18, 2005 | 11:15 PM
STEVEN13's Avatar
STEVEN13
Looks awesome!!!
Not to be a wise guy but the bolts for the upper ball joint should be bolted in from the bottom not the top. The load pushes up.
I just did upper and lower balljoints on my 1992.
Steven
Old Sep 18, 2005 | 11:17 PM
STEVEN13's Avatar
STEVEN13
Just wanted to add-what did you use on the black inner fender wells?
Steven
Old Sep 19, 2005 | 07:01 PM
onetrackmind
Originally Posted by STEVEN13
Looks awesome!!!
Steven
Thanks Steve, I was not sure which way they went, its not too hard to change them around, also I used armor all on the inner fenders.
Old Sep 19, 2005 | 09:16 PM
the blur's Avatar
the blur
please explain what difference the bolt direction makes.
there is still load on the top and bottom. nut and bolt .
Old Sep 19, 2005 | 11:23 PM
STEVEN13's Avatar
STEVEN13
I should of said that a greater load pushes up. The (GM) shop manual clearly shows a picture of the bolts going in from the bottom and says "Bolts must be mounted in the direction shown"
Steven
Old Sep 20, 2005 | 12:42 PM
grayml's Avatar
grayml
How long did it take to do this job, what was the cost and did you have to use any airtools to break things apart? Mine needs bushings too.
Old Sep 20, 2005 | 02:17 PM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Were the a-frame bushings hard to replace? Any secrets to pass on with this rebuild?
I just completed replacing all rear bushings to include u-joints. How long did it take you to complete the front end rebuild?
Old Sep 20, 2005 | 02:42 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Makes a heck of a difference.... and an even more pleasure to work on when she's clean.
Old Sep 20, 2005 | 08:34 PM
onetrackmind
The bottom a frame is alot easier that the top. On the bottom the bushing can be pressed out the same way you did the rear. On the top you have that shaft that connects the 2 sides together. What I did was to trim the edge off of the the bushing on the end with the small washer then put a socket extension through the hole closest to that end, put it in the vise and carefully push that end out. The other end will slide out of the center of its bushing. I like to take my time on these things. And the ball joints are a bigger pita than the bushings. I took a total of about 3 days to do the whole thing, but thats everything including cleaning all the parts.
Old Sep 20, 2005 | 08:36 PM
onetrackmind
Is that a new rotor or did you clean that up with something? Looks awesome!
To Front end rebuild
