Oil Temp
Old Sep 18, 2005 | 10:07 PM
Biff Buyer's Avatar
Biff Buyer
Default Oil Temp
I have a 85 vette and my coolant temp gauge isnt working. Either its my dash or sender, who knows. Anyways my oil temp gauge is still working. Whats a high and normal temp for my oil?
Old Oct 29, 2005 | 04:55 AM
86PACER's Avatar
86PACER
For me around 200-225 degrees is normal operating oil temperature. Depending on how I'm driving. If you start to get upwards of close to 300 degrees, that's high for stock.
Old Oct 29, 2005 | 07:36 AM
sami85L98's Avatar
sami85L98
180-220 (220 when extremely hot weather and stuck in traffic).
Otherwise 180-190 some never goes more than 200 in normal hwy driving.
Old Oct 29, 2005 | 07:53 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
My LT1 is obviously different and I use Mobil 1 synthetic, so supposedly that's safe up to 300, but I've never seen more than 260 under hard driving conditions and 200-220 is the normal range.
Old Oct 29, 2005 | 12:00 PM
kopbet89c4's Avatar
kopbet89c4
At one point, I took my oil to 264 degrees F and the oil pressure at that temp dropped enough to light up the red light when cornering hard. When my oil is at a lower temperature, let's say below 200 F, it doesn't drop when cornering. Why?? BTW I am using regular, generic, non-synthetic 5w-30. Does that have something to do with it? Would a thicker oil help, such as 20w-50??
Old Oct 29, 2005 | 12:13 PM
CFI-EFI's Avatar
CFI-EFI
Your '85 and my '84 share the same long block. I rarely see over 235°. It is easy enought to test your engine coolant temperature gauge sendig unit.
RACE ON!!!
Old Oct 29, 2005 | 03:12 PM
froggy47's Avatar
froggy47
200 -230 cruising, 280 - 350 or a bit more racing.
Old Oct 31, 2005 | 10:35 AM
williammackean's Avatar
williammackean
St. Jude Donor '07
I have the exact same symptom on my stock '85. My oil runs around 235. This might be high. I also have intermittent heater symptoms. I checked the radiator. It was full. Then I opened this Coolant Flush plug on the PS of the engine bay. Nothing. My plan is to make sure to bleed the system when I do my TB bypass this week. I'll check the sensor while I'm there. Let's let each other know what we find.
I have never had to bleed a cooling system before. Anyone have any tricks?
To Oil Temp
