ignition cutting out
Old Sep 18, 2005 | 11:07 PM
TroyDest's Avatar
TroyDest
Default ignition cutting out
Help! Bought a '92 LT1 6-speed two weeks ago. About ten minutes from the guy's house, the ignition seemed to cut out and the motor fell on its face. At the same time, it was backfiring. The revs dropped down to about 1000 and then was idling fine. Until the motor fired back up at 1000, hitting the gas did nothing at all which seems to me that the ignition was off. The motor never did die completely; it idled just fine. I could drive for about 20 seconds and then it would happen again.
The car was pretty hot at the time and I thought maybe it was overheating. I shut it off and let it sit for about 1/2 hour to cool off. The coolant looked like mud. After it cooled off, it ran fine again and I was able to get home about 7 minutes away. I flushed the coolant last weekend and then the water pump started leaking. It didn't look like it had been leaking until then. I replaced the water pump, plugs, wires, thermostat and rad cap this weekend. I just went for a drive and the same problem occurred - after about ten minutes of driving the engine died and would only idle. Once it is idling OK, I can give it gas and hold it at a steady RPM for about 5 seconds until the motor cuts out again. Any ideas? Is this how the Optisparks go out?
Old Sep 19, 2005 | 01:15 AM
Morley's Avatar
Morley
I bet the guy that sold you the car put some kind of leak stop in the cooling system because the pump was leaking/shot and he just wanted to sell it. and if it were leaking before, it probably took out the opti..
One "cheaper" thing you could try is to take it to a dealer/speciality shop and have them diagnose the ignition system. It may end up being the ignition module...keep your fingers crossed.
Oh...flush out that cooling system throughly and get all of the "mud" out...run the heater while flushing.
Old Sep 19, 2005 | 06:00 AM
93 ragtop's Avatar
93 ragtop
One other thing I wondered about. Had he washed the motor before selling it? The early opti's have little to no tolarance to water.
Old Sep 19, 2005 | 02:38 PM
TroyDest's Avatar
TroyDest
No, the engine was not washed. In fact, it is still a little greasy. The water pump didn't have any telltale signs (stains) of leakage from the past. It didn't start until I used Prestone Heavy Duty Cleaner (2-part powder)- which is the only thing that works from my past experience. The PO had just smogged it the day I got it with no problem.
I scanned it last night; no problem codes at all! Just 12...12...12...12...12. If it's ignition related shouldn't there be some faults? The PO did have a coil problem recently and the dealership replaced it. Would a faulty coil or coil module cause this running problem. I'm tempted to just throw an MSD coil on it for the hell of it. Thanks guys.
Old Sep 24, 2005 | 01:57 AM
TroyDest's Avatar
TroyDest
Default anybody, anybody?
Come on. None of you guys has had this same problem? It seems like it would be a common symptom of either the Optispark or coil module going out. I'm getting nowhere. I replaced the coil with an MSD Blaster hoping it would be a cheap simple fix - no change. I didn't try a new coil module. The engine is still shutting down when it gets hot (230 F) and you hold a steady rpm. No damn error codes!
I suspected maybe the fuel filter was clogged and after running for a while not letting enough fuel through - the pressure looks good though even when the motor is shutting down.
The ignition is definitely shutting down. The tach drops right to zero as soon as the problem occurs. The tach drops before the engine revs actually come down which tells me that the ignition is shutting off. Today, when I intentionally let it heat up and held the revs at around 3000 to get it to shut down, it would diesel until I turned off the key. It will fire right back up though and idle just fine.
Nobody has experienced the same symptoms? Thanks for any advice.
Old Sep 24, 2005 | 02:33 PM
Morley's Avatar
Morley
see above
Old Sep 26, 2005 | 04:50 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
It's probably the Opti, but make sure all of the wires on on tight and that the ground straps are on.
Old Sep 26, 2005 | 06:07 PM
93 ragtop's Avatar
93 ragtop
Originally Posted by TroyDest
The water pump didn't have any telltale signs (stains) of leakage from the past. It didn't start until I used Prestone Heavy Duty Cleaner (2-part powder)- which is the only thing that works from my past experience. .
Have you checked for leaks after flushing the system. It sure sounds like a bad opti. But im guessing.
Old Oct 5, 2005 | 02:16 AM
TroyDest's Avatar
TroyDest
Default problem gone
BINGO. Problem has gone away with replacement of Ignition Control Module. I just drove it twice for about 1/2 hour each with no ignition problems and I was hammering it. None of the other items I replaced had any effect (fuel filter, plugs, wires, coil, knock sensors, coolant temperature sensor).
I did find a wire unplugged from the transmission when I was under there replacing the knock sensors. It was a short pigtail coming from a solenoid that screws into the rear left side of the ZF 6-speed. I went ahead and plugged it in; I really doubt it had anything to do with my ignition problem though. I don't know what that particular solenoid does. Of course, the POS Chilton is no help.
I guess I'll go ahead and start driving my "new" car now and register it in my name!
Old Oct 12, 2005 | 07:59 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default CAGS plug
BINGO. I did find a wire unplugged from the transmission when I was under there replacing the knock sensors. It was a short pigtail coming from a solenoid that screws into the rear left side of the ZF 6-speed. I went ahead and plugged it in; I really doubt it had anything to do with my ignition problem though. I don't know what that particular solenoid does. Of course, the POS Chilton is no help.
Congrats on solving the problem. BTW, the unplugged connector was probably for the CAGS (forced shifting from 1st to 4th), and the previous owner has just unplugged it.
I presume now if you go easy on the throttle when taking off, the trans is now preventing you from shifting into 2nd.
If you want to disconnect it again, I would suggest instead of just leaving it disconnected, risking plug corrosion and possible DTC's, installing the CAGS bypass plug, available from Ecklers via this link: http://www.ecklers.com/product.asp?p...A7K4URWN8V9H1E
Hope this helps..
To ignition cutting out
