Rear Brake Job Question
Old Sep 20, 2005 | 01:48 AM
Sidney004's Avatar
Sidney004
Default Rear Brake Job Question
When replacing the rotor on a 1994 LT1, do you remove the parking brake spring, if so how? or do you deactivate the parking brake adjuster to slacken the cable as per the manual? If the proper procedure is to slacken the cable, please tell me the trick. I have got the parking brake cover off and cannot see how this is done. Please help!!!
Old Sep 20, 2005 | 03:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I did rear rotors & pads on my '88 I just used a pair of plyers and muscled the spring off without touching the parking brake lever mechanism. I believe there are brake tools that would ease the job of removing/replacing the spring.
Old Sep 20, 2005 | 07:19 AM
runner140*'s Avatar
runner140*
There is a tool that is available at all good parts stores and you will recognize it when you see it. When I did mine, I used an old set of pliers-- the old way when you don't have special tools.
Old Sep 20, 2005 | 10:31 AM
Sidney004's Avatar
Sidney004
Thanks, I thought fooling with the parking brake adjuster was the wrong way to go.
Old Sep 20, 2005 | 11:40 AM
FDAMFA's Avatar
FDAMFA
Just popped the spring off my 92 then popped it back on when done
Old Sep 20, 2005 | 05:12 PM
sreginullik's Avatar
sreginullik
Cruising
does anyone have directions on how to replace the rear pads?
ive never done brakes before. how long does it take.
To Rear Brake Job Question
