TFS Heads on L98. Spring options?
Old Sep 20, 2005 | 07:00 AM
rodj's Avatar
rodj
Default TFS Heads on L98. Spring options?
Need to change springs that came with my TFS 195s for something suitable for.550 - .600 lift.
Any recommendations?
What retainers did you use?
As supplied has 1.25 springs and retainers.(Base 195 , only ones avail off the shelf here)
TFS has 1.460 dual spring option good for .600 but expensive to source in this part of world.
Old Sep 20, 2005 | 09:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
What open/close spring pressure does your cam call for?
Old Sep 20, 2005 | 03:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Have you considered the Comp Cams bee hive springs, I'm not sure if they go to .560" or .600"??
Indeed you need to know the seat & over the top pressure from your cam mfg.
To TFS Heads on L98. Spring options?
