What would I be looking at for HP gains? I have a LT4/ hot cam, headers and side pipes and running an OBD1 reprogramed computer. Its in a 64 Corvette GS. I am thinking it may not be worth the investment???? Thanks
Are you speaking from experience?! But you'd have to admit, once it's done it's worth the effort!
I'am. My LT4 with 62K mi lasted less than 1K mi with an ATI prochager with 4 1/2 Lbs boost. Experts I have read say that you should not boost an engine with higher than 9.8:1 compression. My FMU failed/or was defective.The experta at EFI University say don't trust FMU's. Tune the ECM, and always use a wide band O2 sensor, and keep the a/f ratio at 11:1 for high boost, and 12.5:1 for light boost. Easier said than done, but worth the effort in my opinion.
i know im new at forced induction but what is alky injection? is it part of an intercooling device for a blower? i looked at hte packages for the LT4 on his website and those are some impressive numbers. im assuming most of those are with forged pistons and reduced compression ect to run about 12lbs of boost but is that on a stock displacement? 349ci?
Alky / water injection is added at high pressure about 100psi through a nozzle in the intake to cool the intake air coming into the engine, typically it is good for another 75 or so horsepower...
It is used either alone or in place of a air / air ntercooler... or both together, depending on what you are doing...
Most of the numbers you are seeing are from lt1 350's there are a few runing 383's and fewer 396's about the are supercharged...
Mo
DAMN! so if i got the kit for 600hp from that site and bored and stroked my engine to a 396 i could potentially see even more power?
no, it really is dependant on how hot the incoming air is enterng the intake, it is not like a shot of NOS...
The 75 hP is roughly the gains I saw..
Mo
im sorry. i wasnt talking about alky injection. i meant if most of these guys are using kits from blowerowrks on stock discplacement motors and getting close to 600rwhp i should be able to get quite a bit more with a 396 motor
thanks when the time comes $$ will go into a rebuild and not supercharging my LT4.
Probably a wise choice, but I ran a intercooled procharger on a ls-1 camero with alky/water injection, comp cam, adjustable timing, special chip, etc. THERE IS NOTHING LIKE THE SOUND OF A SUPERCHARGER AND A GOOD EXHAUST SYSTEM. I ACTUALLY HAD TRAFFIC COPS TO WAVE ME OVER TO ASK WHAT I WAS RUNNING AND HOW FAST WOULD IT GO. DO MISS THAT CAR!!! Superchargers need: low compression, water alky injection, good timming. I had over 500rwhp and 20+mpg on the highway.
IMHO the LT4 is built around old school normally aspirated HP hence the high compression ratio. For the cost of a supercharger, comp ratios changes, or a high dollar blower with low boost which defeats the purpose of the blower in the first place, you may be disappointed. You can build a reliable very quick car working with the platform you already have such as performance tires or drag radials, driving skill, a good clutch, sensible engine mods, programming etc.
If you must blow, leave the LT4 alone. Find an LT1 engine which is cheaper and more plentiful than the LT4. Take your time and build the engine on a stand for the boost you want. When done, swap your blower built LT1 where your LT4 used to live. Obviously pcm changes/programing will be required.
