Supercharging an LT4?
Old Sep 22, 2005 | 12:18 PM
jv1021's Avatar
jv1021
Default Supercharging an LT4?
I have had my LT4 coupe since May and the car is fast already, but I want it to go faster. I'd like to supercharge it but I have talked to some people and they say it not a good thing to do with the LT4 because it burns the engine up? Is this true or do they not know what they are talking about? Would it be better to turbocharge it? or not doing any forced induction at all? Help me out!
Thanks,
Jake
Old Sep 22, 2005 | 12:45 PM
zelement's Avatar
zelement
just leave it alone. unless you got $30K laying around and don't know what to do with it.
Old Sep 22, 2005 | 12:46 PM
TM-Z06's Avatar
TM-Z06
Supercharging is not a good ideal when you have a 10.8:1 compression ratio.... and hypereutectic pistons.
If you want to supercharge it, build a forged bottom-end and lower the compression ratio. Otherwise, have the heads/intake ported, get a custom cam, a full 3" exhaust and tune, and you'll get 380-395rwhp. Several guys on this forum with LT4's have gone the N/A route and have very impressive numbers.
Old Sep 22, 2005 | 01:57 PM
drochau's Avatar
drochau
If you can't afford the engine rebuild when it eventually blows you probably shouldn't supercharge the LT4. Though after my rebuild things weren't so bad as the compression was lowered to a functional 9.2:1.
For what it's worth, if I started from scratch I would probably go the N20 route instead. Build the heck out of the motor and drop a 250+ shot, or maybe a couple of stages of N20. Woulda been alot cheaper plus a heck of lot less headaches.
My .02
Old Sep 22, 2005 | 05:41 PM
Zix's Avatar
Zix
Are you speaking from experience?! But you'd have to admit, once it's done it's worth the effort!
Old Sep 22, 2005 | 05:51 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
It can be done. Talk to Greg with Blower Works at www.carrollsupercharging.com/ . He has a kit developed for the LT-4 and makes aroud 500 HP. I am getting ready to install the kit on my 383 LT-4.
Michael
Old Sep 22, 2005 | 11:19 PM
zelement's Avatar
zelement
Don't ask me how I know....yeah, its coool when done but when is it ever?
Old Sep 23, 2005 | 12:52 AM
bacardioil's Avatar
bacardioil
your right paul when is ever done, i know
Old Sep 23, 2005 | 03:46 AM
Mo_Bandy's Avatar
Mo_Bandy
It brings out the froggie within.... "Are we there yet?"
NEVER done.....
Mo
Old Sep 23, 2005 | 04:55 AM
Mad-Mic's Avatar
Mad-Mic
it can be done but it is very tricky. i know where a LT4 vette is with a procharger setup on it putting out 7 lbs of boost on the stock long block and runs damn good. pulled 460 to the wheels. take alot of timing out and add alot of fuel and it can be done.
our first top alcohol dragster we ran was 12:1 compression with a 1471 psi blower. anything can be done but you better have deep pockets cause if 1 cylinder goes alittle lean there is no give in a 10.8:1 street application.
Old Sep 23, 2005 | 10:41 AM
GeosFun's Avatar
GeosFun
First look in your wallet and decide how fast you want/can afford to go. Be specific: How fast in mph and how quick an ET (if drag racing is what you are talking about). Also consider state smog compliance. The alternatives to reach that level of performance will become apparent as the parts necessary to do it are known commodities.
If you read the supercharger button on this forum, there are a lot of unhappy supercharger owners and a few who go like stink and are thrilled. I think the latter stepped up to the pay window.
Old Sep 23, 2005 | 11:50 AM
TM-Z06's Avatar
TM-Z06
If you're dead set on supercharging the LT4, get the compression down. Either go with a set of AFR 195cc heads with a 62cc (or bigger) combustion chamber, or have your LT4 heads worked to increase the size of the combustion chambers. Add some 1.7 rockers, a bigger TB, full exhaust, a Carroll (Vortech) supercharger, bigger injectors, and a bigger fuel pump...... with a tune, you'll have one nice street-able 450+hp combination.
Old Sep 24, 2005 | 01:30 PM
jv1021's Avatar
jv1021
Thanks for the help guys.
TM - If I decide to supercharge it, I think I will go that way, it sounds like the better way to me
Old Oct 2, 2005 | 04:28 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Michael
What did the kit cost you???
Which kit did you buy from him?
What's the compression ratio of your 383?
thanks
robert
Old Oct 10, 2005 | 06:40 PM
88BlackZ-51's Avatar
88BlackZ-51
it never is....
Old Oct 13, 2005 | 08:24 PM
Rkreigh's Avatar
Rkreigh
with a good tune you could run some boost but the pistons aren't designed for it. if you want to put a kit on the car, get it tuned well and consider alchy operation for higher boost.
chances are the pistons won't last very long, and I agree it would be better to freshen it up with the right compression, run a bit more boost rather than low boost and high compression.
the little turbo buick runs pretty good at 26 psi, but we break alot of stuff too. :o
Old Oct 14, 2005 | 08:41 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default LT4 S/C Kit
I've Been Making A Kit For The LT4 Since It Came Out. Boost Restricted To Around 6-7 Pounds And Of Course It Includes My "Gaseous Intercooling". When Done Properly And You Limit The Boost, It Screams. Of Course The Engine Potential Is Far Greater With Forged Pistons And A CR Reduction.
Regards Greg
To Supercharging an LT4?
Old Oct 14, 2005 | 08:19 PM
Bam's Avatar
Bam
Yeh More Boost On A Stout Will Ensure Blow-up.
Be Cool
Old Dec 19, 2005 | 07:12 PM
vstol's Avatar
vstol
So it looks like having a Hot Cammed LT4 is not a good candidate for supercharging?
Old Dec 20, 2005 | 05:20 AM
BlowerWorks
Supporting Vendor
If it's done right (boost limited to 5-7 lbs) and it includes water/alcohol injection along with a proper 'PCM' re-flash it'll last as long as a stock LT4: all things being equal (like running the injection reservoir empty and still stumping on it). I've got customers with LT4's that have been running since 1996. The pistons are plenty strong as long as you don't let it detonate !!!
Regards Greg
