Zex Nitrous
Old Sep 23, 2005 | 09:19 AM
Brian9's Avatar
Brian9
Default Zex Nitrous
Was looking around at different nitrous systems for ease of use/installation as well as price and safety. Can anyone here comment on this system? (see link below)
http://www.prostreetonline.com/buy/z..._nitrous_kits/
I gotta run to work now but cant wait to get home and read what you all have to say about it. Thanks!
Old Sep 23, 2005 | 10:18 AM
Biff Buyer's Avatar
Biff Buyer
Never seen a Zex system but ive heard alot of people say it's poorly made. I have seen a NOS kit and Nitrous Works kit though and the owners love them. For that price you can get a EFI plate system.
Old Sep 23, 2005 | 11:42 PM
LT4-Z51's Avatar
LT4-Z51
I just installed the zex wet system on my LT4 & love it , I also did alot of research & even the local speed shop said zexs all the way.It is not poorly made & is fairly simple to install about 4 hours to install & it is definately the safest sytem out there.Just remember to change your plugs , gap 38 plug NGK TR6
Old Sep 24, 2005 | 07:20 AM
Brian9's Avatar
Brian9
Thanks to both of you for your feedback about the system Ummm Lt4-z51 do you have any pics of it installed? where did you install the bottle? and did you have to change anything on the engine from stock or just the plugs? Thanks....
Old Sep 25, 2005 | 12:41 PM
redbullapril23's Avatar
redbullapril23
make sure you get the 75-125 wet shot youll def want that. too bad they dont offer a 75-175. that was one of the reasons i went with nitrous works. I love the kit and absolutely love the nitrous! its so addictin!
and also its really vague about what acutal components come. if you get all the safety stuff(which i highly recomend.) youll want a purge kit, hobbs switch, fuel cut off, gauge for the bottle, bottle heater.
thats all about another $500-$700. in my mind its a must. i got it all just to be 100% safe!
your friend
Sean
im guessing u got an lt1 as the kit in the link is for lt1 or ls1
Old Sep 25, 2005 | 02:03 PM
Biff Buyer's Avatar
Biff Buyer
when i hear ZEX, i think of Ricers and tuners. TPIS offers a zex system so that kinda changed my veiw of it.
Old Sep 26, 2005 | 10:26 PM
Brian9's Avatar
Brian9
your friend
Sean
Old Nov 7, 2005 | 01:19 AM
CMYC4's Avatar
CMYC4
I run a ZEX dry on my 91, no problems simple to install! But have no problems w/ a wet kit! Its what you want, their both gonna work!
Old Nov 7, 2005 | 09:43 AM
DSSKing's Avatar
DSSKing
I have the ZEX kit on my 88 L98 and am very pleased with it.
The reason I went with it was simply due to the built in safety system.... Fuel shut-off and Nitrous shut-off built into the box.
No messy selonoids to install..... one in, one out.... that's it.
On a 75HP shot, gears, exhaust, minor mods, the car has run
12.50 @ 104.......
Old Nov 7, 2005 | 06:52 PM
CMYC4's Avatar
CMYC4
IM with you on the safty system DSSKING! Can't beat it.....
Old Nov 8, 2005 | 02:20 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The Barry Grant would be the best kit for your car .I hope you know you can't take it to the track with the nitrous.
YOu can't go faster than 13.49 and with some good race gas and a set of tires you are already their.
The tires you have on the car now will have to go ,nitrous will blow those tires right off.
Old Nov 8, 2005 | 08:42 AM
~db~'s Avatar
~db~
Is this true of all 1/4 mile tracks?? I have one down here in Bradenton and I and people I know have had their cars on there often while spraying. No one asked of course so I didn't share....
Old Nov 8, 2005 | 04:50 PM
RonnieW's Avatar
RonnieW
He is saying that you will run too fast with the nitrous (unless you have all the safety equipment). Nitrous is not illegal or anything.
Old Nov 8, 2005 | 10:35 PM
redbullapril23
the thing oyu have to have for the track is the blow down tube!
so if the take gets over a certian psi and the disk breaks then it vents it outside of the car....
this is an NHRA regulation....
Old Nov 9, 2005 | 12:35 AM
REDC4CORVETTE
You have a rag top ,that means if you go faster then 13.49 in the 1/4 you will need a roll bar..................
With a good set of tires you already will run close to that number if not under.
My rag top went 13.70 first time down the track.
With 1.6 RR and beehive comp cam springs with a power programmer ,Nitto drag radials 315+45+17 rear it runs 13.30
a 100 shot of nitrous will put you down the track at 12.55 if you alighn the rear end right.
To Zex Nitrous
