Octane Booster
Old Sep 25, 2005 | 12:43 AM
MetalVette's Avatar
MetalVette
Default Octane Booster
Are there any octane Boosters out there anyone could recommend. Here in CA the best we can get is 91 Octane. I was just in Alabama and they have 93.
Old Sep 25, 2005 | 10:41 AM
Atok's Avatar
Atok
If your LT4 is stock you don't need more than 91.
Old Sep 25, 2005 | 11:23 AM
CFI-EFI's Avatar
CFI-EFI
Is it knocking? Are you observing timing retard?
RACE ON!!!
Old Sep 25, 2005 | 03:06 PM
MetalVette's Avatar
MetalVette
No, runs great, just looking to see if higher octane would make any difference.
Old Sep 25, 2005 | 03:09 PM
hippy's Avatar
hippy
It will make a difference, if you aren't pulling any timing out due to knock you'll run slower.
Old Sep 25, 2005 | 07:05 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
OCtane will do nothing for you if you don't need it. It burns slower than a lower octane fuel.
Some of the VERY VERY high end race fuels are oxygenated, which will produce more power, but they are near 40 dollars a gallon! You better have a bunch of sticker on your car and be bringing home lots of cash to run one of them. But they will make more power.
That I guess is the common misconception with racing fuels. People think that if you run them you will make more power. Not the case if the motor is not built for it. The power itself comes from compression. The tighter the squeeze, the bigger the bang. Think of gunpowder...pack it loosely it will pop. Pack it tight it will go kaboom. With the tight scenerio a common gas octane like 91 will detonate due to the pressures before the spark plug even fires. Higher octanes will withstand the pressures more and then explode with the addition of the spark.
You don't need to worry about it.
Old Sep 25, 2005 | 07:18 PM
c4cruiser's Avatar
c4cruiser
91 octane will be just fine. Here in WA we have 92 octane and I have never seen any indication of ping or spark knock. Been to CA a number of times and never noticed a difference (except for the prices )
I have even run 89 octane in my modded 87 and the only time I have ever heard a obvious ping was at WOT or going up into the mountains on long steep grades. Around town there were no problems.
Old Sep 25, 2005 | 08:34 PM
Cherry6speed's Avatar
Cherry6speed
Higher Octane will do nothing for your car. Run a data log or Obd1 scan tool and look for knock counts. You can try seafoam or marvel mystery oil to de-carbon your engine if that is the source of pinging. We used to smoke-up the whole shop de-carbonizing but, the results are worth it. Most older, higher mileage engines can benefit from combustion chamber cleaning. Try transmission fluid, it has an awsome cleaning agent also. We used to pour it right down the carbs but in your case try using a vaccum port. good luck
Old Sep 26, 2005 | 04:38 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Do all these octane boosters actually boost octane?
Some i've read the label on, merely remove deposits to "reduce the engine's octane requirement". Which is total b.s., sorta like claiming a 12 guage is a cure for diabetes.
Old Sep 26, 2005 | 07:27 AM
Atok's Avatar
Atok
Yeah, some of them do. We run one of the 104 boosters in the 91 octane gas we race with. The engine detonates on 91 alone without the booster. Actually, we melted 5 pistons in 25-30 laps one year. Octane boost was in the car for every race after that along with knock sensors with a dash light.
Old Sep 26, 2005 | 10:56 PM
MetalVette's Avatar
MetalVette
so dose 104 work or not?
Old Sep 27, 2005 | 07:44 AM
dand1892's Avatar
dand1892
Isn't there a scale what each octane is good for a certain range of compression
To Octane Booster
