Opti Spark Eliminator??
is anyone currently running any of the three listed bellow and what comments do you have?
i think my opti is going out cause after a cooling fan replacement the car started to mis and backfire- why do they put the bleed valve for the collent directly over the dist?? since all of these routes are expensive i would only like to spend the money once-
LTCC
DYNOSPARK
DELTAQ
thanks in advance for your feedback
LTCC
DYNOSPARK
DELTAQ
LTCC
DYNOSPARK
DELTAQ
The Delteq kit is a completely different story, they sell everything as a ready-to-bolt-on kit. All pre-fabbed up, for about the same price as the complete LTCC kit. Wires, brackets, mounts...you name it, and it's done for you. And from what I hear they have great customer service as well. This is a much easier solution, the one advatage the LTCC kit has is the 8 coils vs 4 coils for the Delteq.
The Dynaspark is an upgraded opti. Personally, I can't see spending $600 on a billet opti unit. I'm sure it's better than the OEM GM unit, but it's just not for me. The major advantage the Dynaspark as over the LTCC and Delteq is the fact that all you are doing is swapping the Opti out, very easy install with no extra fabrication necessary.
LTCC
DYNOSPARK
DELTAQ
I installed a DynaSpark in my '94 last year, and I'm very happy with it.
The DynaSpark is completely sealed, and DynoTech actually encouraged me to go ahead and hose down my engine whenever I want to. DynoTech analyzed the OEM Optispark distributor to identify all of its problems, and engineered a bolt-on replacement for the Opti, that attempts to address all of the design- and process-related deficiencies of the OEM units. I'm very impressed with it.
The Delteq system is a Distributorless Ignition System (DIS) upgrade that eliminates the cap & rotor portion of the Opti by replacing it with four Cadillac Northstar wastespark coilpacks. Converting to the Delteq requires that you continue to use the Opti's triggerwheel and optical sensors to feed the necessary camshaft position/velocity/accelleration data to the ECM which then triggers the Northstar coilpacks.
The LTCC system works in much the same manner as the Delteq, but uses eight LS1 coilpacks instead of the four Northstar coilpacks that are used by the Delteq. If you convert to the LTCC, you will still be required to use the Opti's triggerwheel and optical sensors, same as with the Delteq.
Be well,
SJW
Optis fail in one of two ways:
1.The cap and/or rotor fail.The cap can be come imbedded with carbon tracing causing misfiring.The rotor can fall apart.You may not get a SES code for this but the car will run like crap.
2.Something (other than pieces of the above) gets inside blocking the optical pickup and causes a SES fault code(16and/or36 on my 93).This is usually what happens when the WP dumps on it.
You can modify early optis (see my pics)to be vented like the 95-96 version which helps.You can RTV the cap and plug to seal it better to prevent moisture intrusion.On the one in my pics the plug area had a bead on it the only problem was it was just lying there not attached to the cap except for one little spot.
Optis can fail due to chain/gear wear inside the timing cover.The added vibration causes the bushings to prematurely fail.
The Dynaspark addresses all these issues inculding the venting for the pre95 cars and usesz bearings instead of bushings.I did the reasearch before I chose it.Do some searches in the archives on the Opti for more detailed info.....
This is for all newbies, it really helps if you include anything that was changed prior to a problem occuring.A lot of the time a mechanic screws up things around what they are fixing(guilty myself) so the location of repairs can point to things around it that may help get your car running right.The more history the better.
Also, since it was only 2k ago the opti was replaced, could it be something tied to that replacement which has just shown-up now, e.g. something not tightened and/or has loosened-up?
What is the running temp (digital and analog) of the engine now since the fan was replaced?
Does the problem happen when it is cold, or only after warmed-up?
Is it possible that the overheat (although 245 isn't that hot), caused an air pocket in the coolant in the block, causing hot spots? Have you checked coolant level and cracked the two bleeders to assure no air pockets (with lots of paper towels underneath to protect the opti)?
Hope this helps..
About the price it seems fair for a well made unit, no improvisation here!
