Unusual Problem with running hot
Old Sep 25, 2005 | 04:17 PM
David Joseph's Avatar
David Joseph
Default Unusual Problem with running hot
Recently I had my left fan motor replaced, my radiator cored (cleaned) and a 160 degree thermostat installed. The car runs fine around town. Recently, however, at highway speeds, the temp goes up to 120 when it used to hover around 200! I am at a loss. Could I have a bad thermostat?
Old Sep 25, 2005 | 04:56 PM
bmalec's Avatar
bmalec
Possibly, but wow, 120 degrees is pretty low. Are the temperatures around town pretty much what you'd expect? Even with a 160 degree thermostat, I'd still expect the car to get past 200 pretty easily when stopped in traffic.
Ben
Old Sep 30, 2005 | 12:39 PM
xflagz51's Avatar
xflagz51
Default Maybe, but not likely.
It could be a failed t-stat, but it should run cooler on the highway than it does in town. When I bought my '90 it had a blown A/C condenser and that caused problems, but around town. Highway was fine. It doesn't make any sense that it's running hotter on the highway. Also check and see if you've got air entrained in the cooling system. That's a strange one, best of luck.
Old Sep 30, 2005 | 01:34 PM
zr1-2go's Avatar
zr1-2go
Are you running an aftermarket front spoiler?
What rpm at highway speed?
Old Oct 1, 2005 | 10:58 AM
FD2BLK's Avatar
FD2BLK
I asume you ment 220. If the car runs fine in town and gets hotter on the Hwy then I would take a good hard look at the front valence. Those little spoiler looking things are very important and a much needed part of the cooling system
Old Oct 8, 2005 | 11:51 AM
Guitarguy's Avatar
Guitarguy
where did u buy the 160 thermostat? i ask for 1 from local part stores and they are not the right 1. not sure what year your vette is but if it is 92 or newer and you bought the thermostat from a parts store i know you got the wrong 1 in there. hope this helps
Old Oct 10, 2005 | 02:22 PM
Cashmo's Avatar
Cashmo
http://www.carnut.com/ramblin/_cool3.html has some info you might want to read.
Jeff
Old Oct 15, 2005 | 09:45 AM
TheCorvetteKid's Avatar
TheCorvetteKid
Jeff
Excellent article! Thanks for posting it Jeff.
I swapped out the 180deg tstat I was running for a 160deg tstat this summer. Now that I've read that article, I'm thinkin' I'll pull the 160 and put the 180 back in.
To Unusual Problem with running hot
