trouble code 26
Old Sep 26, 2005 | 12:08 AM
stangetr's Avatar
stangetr
Default trouble code 26
ok guys i went from three codes to 1 after eplacing the ox sensors i am still getting code 26, i have read tons of treads here trying to find a solution or some direction,, i see some things about could be three diff relays , where are they, somewhere else i read that the IAC could set the code,,,,,
any ideas tracking this down would be great... the car is running rich,,, extremely
thanks in advance
Old Sep 27, 2005 | 08:22 PM
stangetr's Avatar
stangetr
Default help
with all you tech guys out there no one has ever had a code 26 come up? com on guys i need to pass inspection- here they wont even put it on the machine with the engine light on
Old Sep 28, 2005 | 02:09 AM
Morley's Avatar
Morley
One of the "relays" it can point to is the cannister purge solenoid. Another possibility is one of the TPS wires shorted.
Old Sep 28, 2005 | 12:26 PM
stangetr's Avatar
stangetr
any idea where i can find the solenoid?
thanks
Old Sep 29, 2005 | 02:18 AM
Morley's Avatar
Morley
thanks
Should be on the top of the evaporative fuel cannister, if not on top, follow the lines off the cannister and they will run to it.
Old Sep 30, 2005 | 06:52 PM
stangetr's Avatar
stangetr
theres some solonoid valve on top of the intake by the front , it has one vac coming from the canister and one going into the intake with 2 wires coming out of it??????????? could it be
Old Sep 30, 2005 | 10:12 PM
Morley's Avatar
Morley
Should be it.
Old Oct 2, 2005 | 10:02 PM
Guitarguy's Avatar
Guitarguy
what year is your vette?, i have the same code. mine is a 1992
Old Oct 2, 2005 | 10:39 PM
stangetr's Avatar
stangetr
mines a 92 also - i think i have located the solenoid but now how do i test it? it seems to be on top of the intake right side front- two wire connection, two vac lines- any ideas?
Old Oct 2, 2005 | 10:52 PM
Morley's Avatar
Morley
Start the engine and let it run for a few minutes, the relay should be pretty warm. If it isn't, use an ohm meter between the 2 terminals on the relay. If it reads very low or infinite ohms, it is bad.
To trouble code 26
