Paging Alvin
Sep 26, 2005 | 08:49 PM
Paging Alvin
Alvin, I have a quick question- if my current tune was set on my existing 52mm TB would I have any problems changing out to a 58mm TB. I simple do not want to go back to the dyno shop and spend another $600 bucks just for upgrading TBs. Your professional knowledge is appreciated.
Sep 26, 2005 | 09:28 PM
St. Jude Donor '05
It shouldn't make any difference AFR wize.. The MAF should compensate nicely for something small like that.
On the auto cars we use a different program per TB to keep the tranny settings right. (94 + cars) Sounds like yours is a manual though so it shouldn't matter.
did you spend $600 for a dyno tune?
Sep 26, 2005 | 09:37 PM
Thanks for the help- yeah its a manual and I did pay $600 for mustang dyno tune. I can't say that I made the RWHP I thought I would either. Chad
Sep 26, 2005 | 09:38 PM
St. Jude Donor '05
damn i need to start charging more
Sep 26, 2005 | 09:39 PM
Quote:
Just keep in mind that a mustang dyno reports much lower #s than a dynojet does. Its just the way it is.
Sep 26, 2005 | 09:48 PM
Quote:
Well when I leave FT Hood?? If I end up at FT Bragg I'll come see ya. Chad
Sep 26, 2005 | 09:53 PM
St. Jude Donor '05
Are you in Aviation?
I tried going to flight school but failed the flight physical.. could you imagine a 180lbs 6'-6'1'' young man could have 3x normal triglicerides?
Sep 26, 2005 | 09:56 PM
No- I'm in the Signal Corps.
Sep 27, 2005 | 12:13 PM
Is you intake ported for a 58mm TB?
