C4 TPI questions...
First off, yesterday I picked up what was supposed to be a TPI setup from a 86..however, after getting it home I noticed a tag on it that says 85.
Can you guys help me figure out which it is and does it matter? What are the differences?
Also, I cleaned up the runners and the plenum pretty good, and went to start working on the throttlebody, I tried to take off the water pass-thru and I ended up snapping the heads off of three of the bolts, the others barely came out.
I just read the excellent thread about the TB bypass, should I just go that route and not worry about it? Or should I scrap the TB?
Any help you could give would be great as I'm really new to this stuff.
I can post some part numbers tonight if it will help.
Oh, one more. Is the IAT on the water pass thru or on the bottom of the intake plenum? I thought the IAT was on the plenum, but the water pass-thru on the TB appears to have another sensor (not the TPS) that has a 4 wire connector....
Thanks!
As for the year. Some major L98 differences would be al heads in late 86 and full roller block starting in 87.
I know there are subtle differences between 85 & 86 (I think).
As for getting those 3 screws out, I'm not sure, I could probably drill them out.
If I plan on doing the bypass, does it matter? Could I just leave it like it is or even just cut it off the TB?
Some easy-outs will remove those busted bolts, just take your time and they'll come out. I recommend doing the coolant bypass, heat soak is a nuisance on these cars. Also, remove your Idle air control valve (IAC) and clean it, it's passages, and the throttle body with THROTTLE BODY CLEANER, NOT carb cleaner. Do the same with the EGR valve on top of the intake manifold.
Replace ALL the gaskets while you're at it. The major differences between an '85 and '86 TPI was the computer PROM and the fuel pressure was 34-38 psi on the '85 and 38-42 psi on the '86+.
Contact me if you have any questions, and good luck.
This would also eliminate the 9th injector.
I would also pick up a helm manual for the year you decide to go with, then you would know all about the injection system and how to debug it.
Another option is to get the book "Corvette Fuel Injection and Electronic Engine Management: 1981-2000", By Charles Probst. It's available from Robert Bentley publishing or Amazon.
I'm not using a stock ECU or harness, going megasquirt:
www.megasquirt.info
The assembly under the TB needs to be in tact as that houses the IAC motor and air passages which control engine idle.
Also you may need different fuel lines as the TPI requires up to 60psi of fuel pressure, usually runs in the 30-50psi range.
Also, I still have to figure out the pump, internal/external, as well as how to mount it.
Alot of folks that have made the switch to EFI talk about putting baffles in their tanks to prevent air pickup due to fuel slosh.
Do the C4 tanks have baffles in them?
There are a few minor errors posted above. I'll see if I can't help straighten them out.
RACE ON!!!
I had thought there were more. Good luck, and...
RACE ON!!!
