LT1 Coolant System Flushing
Old Sep 28, 2005 | 05:51 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default LT1 Coolant System Flushing
Has anyone installed and been happy with a flush adapter (e.g. Prestone’s) in the heater core inlet hose (comes from the lower passenger side of the water pump and has the pressure/flow limiter in the hose)?
Did you do this instead of, or in addition to removing the knock sensors?
Do the knock sensors really need to be removed if flushing the engine with a flush adapter in the heater hose?
Any/all input/thoughts are appreciated.
Thanks.
I should close by saying I am about to do a complete coolant system service. I have already decided to use a 180* thermostat, completely flush the cooling system, remove the radiator and clean its fins and the AC condenser’s fins, so no need to open-up that ‘can of worms’.
Old Sep 28, 2005 | 06:08 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I feel they wouldn't be bad for doing a flush if you knew that your system was 100% But I'd much prefer to drain the block because if there is any significant rust or other contamination, that's where a lot of it is going to be.
Old Sep 28, 2005 | 06:16 PM
Aardwolf's Avatar
Aardwolf
I very much like having that hose fitting! After using the Prestone super flush (drained out into a bottle) I then attached the garden hose and let her flow for 20 mins. There was gunk and color for some time. I really think flushing with the hose helped a ton! I did not remove the knock sensor and just had the radiator drain wide open.
Old Sep 28, 2005 | 07:46 PM
Hotred94's Avatar
Hotred94
I flushed about 25 minutes--color disappeared after about 15 minutes, foam disappeared after about 20 minutes. Between cleaning and flushing radiator inside and out, water wetter, and electric wp, I run about 9 degrees cooler across the board.
Old Sep 28, 2005 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
I love the Prestone flush kit. I have installed one on every car I've owned for decades. If you know the history of the cooling system and the maintenance has been kept up with, you may not have to pull the knock sensor(s). I have never drained my block (via the block drains) nor flushed with anything stronger than tap water. It must work. My radiator core has just finished it's 22nd year of service. I am now back on a once every two year flush schedule, rather than the twice a year schedule I've been in for the last 5 years.
RACE ON!!!
Old Sep 28, 2005 | 08:33 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I use a modified thermostat. I removed the spring from it and in conjunction with the prestone "T" connector I get all the crap out
I take the used coolant to the coolant place
Old Sep 29, 2005 | 08:39 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Instead of draining the block by removing the knock sensors, I attach the hose of my shop vac to the coolant reservoir then reverse the motor on the vacuum to "blower" mode. The forced air moves all the liquid out of the system.
Then, refill as required. Viola! Work smarter, not harder, I always say....
Old Sep 30, 2005 | 01:29 PM
Hotred94's Avatar
Hotred94
Oh yeah, I should have mentioned, if you have an electric water pump, you can just turn it on while you are flushing and it helps move things along. Engine does not need to be running of course. Thermostat is in the way but it does have a bypass hole. You can also flush with water, run the car to open up the thermostat and mix up what stuff is left, then flush again. With the Tee in it is no hassle.
Old Sep 30, 2005 | 02:19 PM
theadmiral94
Default Thanks to everyone
Everyone, Thanks.
Based on everyone's input, I will be installing and using the Prestone flush-adapter in the inlet heater core hose and using the milder Prestone flush (even though manual says not to, the system may not have been properly maintained, so since others have used it, figure better to assure system is clean and then just add the 'coolant system sealer tablets' per the manual to ward-off any leaks the cleaner might cause).
I will also disconnect the radiator hoses during the initial flushing to prevent the 'engine junk' from being moved from one location (engine) to another (radiator) until the water runs clear, and obviously protect the opti from any water. I may also remove the thermostat spring on the old thermostat (great idea, thanks PLRX787).
Also to ONEDEF92, thanks for the Shop-Vac blower idea. I did that on my sailboat diesel engine this year but forgot to consider it for the Vette. So I will be doing it to assure the system is empty, allowing for adding pre-mixed anti-freeze to prevent air entrapment from having to add the straignt anti-freeze first.
Thanks so very much.
Old Sep 30, 2005 | 08:13 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Originally Posted by theadmiral94
Everyone, Thanks.
To LT1 Coolant System Flushing
