Dart Heads
Old Oct 7, 2005 | 09:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
ok. points taken about runner size. I am no expert, but surley if the runner was larger power would be the same as if it was smaller at lower RPM, but whenit is being revved it would allow higher flow. Especially with a non carb engine
No, this is where most guys go wrong, I've done it too. Granted,the newer cylinder low-midlift #'s have gotten better over the years, but bigger isn't always better. Stock runer size is around 160ish, I believe. Look at the above poster's combo. Mild cam, small 180 head, runs 12.6 @108. That's a strong street motor! Those heads will help promote torque wich is what pushes you back in the seat. For a street motor, be a little conservative and build for torque, you'll be glad you did. In fact, many of the newer aftermarket heads (AFR,Dart 180) Can keep up with some 195 heads up to about .550 lift on the flowbench. I don't see where running a bigger cam thatn that is necessary on the street. Remember too, your intake and exhaust system has to be able to move the air, too. Its all in the combination. I've overcammed, overcarbed and "too much cylinder headed" too many cars overthe years before some old timer hot rodders pounded the concept of torque through my head. Used to make fun of the small cams and heads they ran til I took a ride in one, then I was sold on it. Just trying to help.
Old Oct 8, 2005 | 04:52 AM
AusJoe's Avatar
AusJoe
appreciate the advice. I have asked heaps of different people on this one and i have about a 60/40 for against opinion. I will let you know how it goes when/if i do get the heads. but i would still really like to know if the cfi manifold is meaty enugh to support 1206 felpro gaskets???
Thanks. Joe.
