Dart Heads
Old Oct 3, 2005 | 06:49 AM
AusJoe's Avatar
AusJoe
Default Dart Heads
Firstly: I was looking at buying a set of used dart heads (steel)w/ manly stainless valves- 2.06 & 1.60, 64cc chamber to put on my vet. Has anyone had experience with these haeds and or valve combo? i would also like to know, again if anyone uses this set up, or something similar to it what cam you are running and how does it effect engine management systems??
and secondly: i am having a shop tune my vet this week, its long overdue, and i was wondering if anyone has messed with the timing at all? is this a no-no, or can it net some benifit? Cheers.
Joe.
Old Oct 3, 2005 | 09:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
What is the intake cc size? 180, 200, 210?
Stock timing setting is 6 degrees. Some claim theirs runs better with 8-12 degrees, mine doesn't seem to like it.
Old Oct 3, 2005 | 10:24 AM
mseven's Avatar
mseven
First it is going to be hard to get a real defined answer without knowing what year set-up you own. Many have used Dart heads w/good results, but as cuisinartvette stated, which runner size as to match to what you already have, or if you can even use them over 200 no, and 220 probably wont fit. If you are going to change the cam the next issue would be to know if you are keeping the stock intake, again needs to work with that one, or if not, the combo would change again.
Timing is base a no., the comp. should be doing all the global adj. I never got mine to work well above 8*still have at 6*(w/est disconnected) though, others will disagree I am sure
Old Oct 3, 2005 | 10:52 AM
kpforce1's Avatar
kpforce1
I have a set of minorly CNC ported/polished Dart IE 180cc/64cc chambered heads with 2.02/1.6 valves and crane springs rated to .600" lift if they would fit your application better. Like the others said, we need to know what year and what mods you have.
Old Oct 3, 2005 | 03:46 PM
rlane5's Avatar
rlane5
Hi Joe
I have a set of 180 Iron Eagles on my .030 350 engine with a Hot Cam, and I like power the engine makes for a street buget engine the vette runs 12.6s @ 108 with 3.07 gears which isn't too bad.
Old Oct 3, 2005 | 05:53 PM
MrNuke's Avatar
MrNuke
Stock internal/cam '85 with LPE Superram/longtubes/ Dana44 w/3.45's and I'm in the low 12's (should be high 11's after new tranny/tc) after putting on a set of race ported Dart Iron Eagles (200cc runners, 2.02/1.60 valves).
car seems to love 6degrees timing, but I burn my own chips, and I change my timing tables for best performance..
Just added Nitrous to the car.. can't wait how she runs..
Old Oct 3, 2005 | 06:10 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Joe,
You may be a vet.
Your cat's doctor may be a vet.
Your Corvette is not a vet.
It's a 'Vette.
That is all....
Larry
code5coupe
Old Oct 3, 2005 | 08:29 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Do not get angle plugs....
Old Oct 4, 2005 | 05:14 AM
AusJoe's Avatar
AusJoe
My 'VETTE (thanks for the education!!!) is an '84 (cross fire), auto, standard engine bar: iridium plugs, K&N filter, 2.25 exhaust and Chip.
Intake runners on these heads are 215cc, how is this going to be a problem??? the standard heads have what???
the heads are ported to felpro 1206 gaskets, and have had extensive amounts of porting i believe.
Is there anything else i should take into consideration??? ie comp ratio with 64cc chambers???
If i was to advance the timing to 8 degs, would this mess with the computer at all?
what do you mean, angled plugs??? Thanks.
Joe.
Old Oct 4, 2005 | 09:19 AM
mseven's Avatar
mseven
My 'VETTE (thanks for the education!!!) is an '84 (cross fire), auto, standard engine bar: iridium plugs, K&N filter, 2.25 exhaust and Chip.Intake runners on these heads are 215cc, how is this going to be a problem??? the standard heads have what???
If i was to advance the timing to 8 degs, would this mess with the computer at all? what do you mean, angled plugs??? Thanks.
Joe.
There are others here who have more expertise on crossfire than I do but what I can say is the 215/64cc you mention using the 1206 would be a bit big without cam/ intake ( maybe even bigger ci.) etc. to support that size runner. If it wre me, I would be looking at something in the 190/56-58cc range.
I think that others who have (CFI) these will chime in, but I'm not sure that is a roller block, which may change available combinations (heads, cam etc.)
I am sure there are some who may argue this, but the initial of setting 6-8*wont mess up the comp., but when est. is re-hooked up the comp. will adjust it from there. On mine at 8* and above, I felt that the timing across the board became to high (IMO). *8 wasn't bad but I went back to 6* and let the computer do its job. IMO
Old Oct 4, 2005 | 09:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
IMO 215cc is waaay to big for your 350, it just won't run no matter how much cam you throw at it. Shoot for a good 180 head for a street car, 195 max. A good flowing 180 head will be more than enough for any aftermarket TPI intake system, your limiting factor and will make great power everywhere.
Edit: oops, didn't see you have a Crossfire, not TPI.
Old Oct 4, 2005 | 09:58 AM
hz900's Avatar
hz900
I don't know how much material the crossfire intake manifold has, but the tpi manifold doesn't have enough material at the top of the intake ports to support a felpro 1206, regardless of whether that is to big for your 350 or not, which it is IMO. I know the 1206 won't work because it happenned to me. Do a search on my user name from about a month ago, I had a thread with pics. You can make it work by welding material on or using a double thick gasket so I was told, but I don't like having to 'make' things work.
Old Oct 4, 2005 | 12:17 PM
USAsOnlyWay
Dart's angle head is not the L98 angle that you have on your car right now, so on certain longtubes (LPE) there is very very very tight clearance, its doable but there is no reason to try it.
Also, with 215cc on a 383 you better be running a huge cam and winding it up to 7000+ rpm. Since you are running a 350 you should definitly run 180cc they will also do great on a 383 FYI. The giant intake port will kill port velocity at low rpms and I garuntee your motor will be a dog all the way past what your intake manifold will let you rev to. Now, 200s are better, but I think 180s ported would be spot on.
Just my .02.
Old Oct 4, 2005 | 01:07 PM
Deakins's Avatar
Deakins
A few years back a fellow racer ran some CFI and had good luck with it. I believe that he had a modified 4 barrel intake with adapter that matched up to the 1206's well and allowed him to run the CFI on top of it. Actually smoked my Tuned port on the track for point of fact. That combination pulled hard through the mid range with more of a moderate cam so I think you would be happy with the 215's if you upgraded you intake and a few other parts just to make sure you can get fuel to it. I would not put a lot of weight into intake runner size and how the engine will or will not run. The power curve at this level is determined by your camshaft selection not your runner size. You will get good power from low to mid with any cylinder head if you cam it properly until you get a runner into the 250's-285 range and more importantly a intake valve into the 2.200 range. I have a set of 220 cc runners on a 355 and even with one of the most aggressive solid roller cam and ported single plane intake it starts to nose over at about 6500 rpms just for comparison.
Old Oct 4, 2005 | 02:21 PM
kpforce1's Avatar
kpforce1
I have a set of Dart IE 180cc/64cc chamber heads that are minorly ported/polished setup to use 1.4xx" springs i want to get rid of. PM me if interrested
Old Oct 6, 2005 | 04:33 AM
AusJoe's Avatar
AusJoe
ok. points taken about runner size. I am no expert, but surley if the runner was larger power would be the same as if it was smaller at lower RPM, but whenit is being revved it would allow higher flow. Especially with a non carb engine.
Can anyone confirm that the cross fire manifold can support the size of 1206?? do these gaskets have not only a larger port hole, but more area on the outside??
Joe.
Old Oct 6, 2005 | 07:22 AM
mseven's Avatar
mseven
Bigger does not mean better, it is about a combination that works together (intake, heads, cam). Without the rest, it should have less low end, if that's what you are asking
Can anyone confirm that the cross fire manifold can support the size of 1206?? do these gaskets have not only a larger port hole, but more area on the outside?? Joe.
Don't know for sure, but I doubt it, even if there was enough material in the casting, it would then need to be either extrude honed, or cut and then ported and polished to get the numbers up. One way for sure if the intake is off the car, put a 1206 gasket across the ports and see just how big thoses 1206 ports really are, an lt1 barely has enough casting/material.
To Dart Heads
Old Oct 6, 2005 | 10:14 AM
elkabong's Avatar
elkabong
I am running 195s/64cc TrickFlows on my 383 in my 84. I would not go much larger than that. To feed it you would either need a ported stock manifold or a XRam. The guys at http://www.crossfire.homeip.net/ are also experimenting with a siamesed crossfire manifold (I have one yet to install).
Checkout the Crossfire Forum.....
Old Oct 7, 2005 | 04:14 AM
AusJoe's Avatar
AusJoe
well, withouthaving to go to the trouble of taknig the intake off, will this help....
1206's have port hole size of 1.34 x 2.21
can anyone tell me if the CFI manifild will match this?
Cheers. Joe.
Old Oct 7, 2005 | 05:03 AM
AZC4Guy's Avatar
AZC4Guy
I have s et of straight plug Dart heads(aluminum) on my 86. Angled plugs will cause trouble w/ certain headers......
