Noise when turning
Old Oct 5, 2005 | 04:25 PM
landl's Avatar
landl
From: Portland, Oregon . To err is human, to forgive is NOT company policy
Default Noise when turning
My wife has a 1989 vert. When you turn hard left from a stop there is a groaning noise. Doesn't do it to the right.
Any ideas?
Old Oct 6, 2005 | 08:16 AM
1stC3Vette's Avatar
1stC3Vette
My '89 coupe make a whining sound coming from the power steering. I believe it is the belt. I have not replaced it yet. My problem occurs when backing the car into the garage at very slow speeds.
If you find anything out, please post it.
Dino
Old Oct 6, 2005 | 10:36 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Could also be the differential. This is not uncommon and can be corrected, in most cases, by changing the rear end lubricant. Use the recommended GM lube and GM limited slip additive and you won't go wrong.
Is the noise coming from the front or the rear??
Larry
code5coupe
Old Oct 6, 2005 | 11:47 AM
landl's Avatar
landl
The noise seems to come from the left front
Old Oct 6, 2005 | 11:51 AM
rocco16's Avatar
rocco16
Then I'd look at the power steering pump.
Larry
code5coupe
Old Oct 6, 2005 | 11:54 AM
JCD's Avatar
JCD
or a bad wheel bearing. or damage in the caliper/break.
To Noise when turning
