Oil pressure
Old Oct 7, 2005 | 07:28 PM
valkryder's Avatar
valkryder
Default Oil pressure
Can anyone tell me what the oil pressure should read in my '84? Maybe a range, say 55 to 60???
Old Oct 7, 2005 | 08:43 PM
quiksilver458's Avatar
quiksilver458
You will probably get a mixed review on oil pressure in here.. My 84 xfire with a fresh rebuild shows about 60-70psi at speed, and around 40-50 at idle... Some say my pressure is to high. I am not sure. Ever since I've owned the car (8 years) it has always reflected a PSI over 60. I now have a fresh engine, new sensors, and new digi dash, and im still getting approx. the same readings. I would say if your over 15-20psi at idle, your fine.
I have read - rule of thumb, 10psi for every 1k rpms.. Not sure how true this is though...
Old Oct 7, 2005 | 08:54 PM
BamaVette87's Avatar
BamaVette87
After my engine is fully warmed up, I get 20-25 psi at idle (~700 rpm) and around 55psi at 2000 rpm (about 70 mph). That's for an '87 w/ 100K miles.
Old Oct 7, 2005 | 09:12 PM
bogus's Avatar
bogus
The 10psi per 1000rpm is a good base line, but it is a bit low.
basically, if it's below that, your hosed.
The numbers that BamaVette quoted are real good... and about where it should be.
Old Oct 7, 2005 | 09:39 PM
AFogleman's Avatar
AFogleman
My 86 with 105,000 miles is about 65-70 at startup.Then once warmed up @ 750rpm it sits above 40.This is with mobile one 15-50
Old Oct 8, 2005 | 02:10 AM
vader86's Avatar
vader86
Spec is 50-60psi warm, with your foot on the gas...and about half of that idling.
In my opinion, more is better, so dont be alarmed if its higher. I wouldnt be worried until the idle pressure drops to single digits or the cruise pressure drops into the 40s.
Old Oct 8, 2005 | 12:55 PM
aboatguy's Avatar
aboatguy
Hot, idle oil pressure is also viscosity dependent for example 5-30 will register lower than 15-50 or 20-60.
Mike
Old Oct 10, 2005 | 12:06 PM
valkryder's Avatar
valkryder
Thanks guys. I seem to be right in there. My worries have abated.
To Oil pressure
