I may need a spare opti to use wiht my DELTEQ,if the OPTI was destroyed last night. ANyone want to contribute to the Steve40th foundation for bad luck? 94-97 Optis?
even if the rotor exploded, I would not expect the opti body to have been hurt. Get the cap thingy from DelTeq and all should be ok.
But the sensor may have been destroyed? I need to take it out, but soemthing is broke as it has no idea where to send spark, IMHO, right now. I will code it here in a little bit, to see if anything shows up, but I am going to also look at O2 sensors integrity (maybe one of them disconnected, broke?) I will take some plugs out, one each side, and check all obvious things.
The sensors are protected... there is a metal plate that separates the 2 sides.
If it's bad, you would get codes... I read somewhere that DelTeq was having issues with 94+ systems...
I emailed Pete at DELTEQ. I didnt hear anything on the 94+'s haveing problems.I need a real good set of pics of a Opti taken apart to see what part I am thinking may have been broken, if it is broken at all.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by STL94LT1
Steve, I have a 94 opti that you can have. But, it is different from the 95-97. Which one do you need?
-Mike
If you have the later, vented style, you need a '95-'97. I too have a used '94 that I have for sale cheap, but would send to you for shipping if it would help. But I don't think it's what you need.
Steve did you convert the timing cover when you had it torn down?The newer Optis have a disc instead of a spline like on my 93.92-94 were the spline shaft unvented 95-96 were disc shafts with the venting.Some people upgrade when they do the cam/timing chain upgrade but it requires changing the timing cover too.If you have a 95 opti you or someone must have done it.
I used the 96 cover and a 95-97 Opti from Superior Chevrolet doing there upgrade. I already had the cover so I ordered everything to convert to the 95 stuff. Do you think my Opti with my 96 cover may be a problem?
Nope no problem all covers are interchangable between all years.I have a 93 opti with a 95 cap converted for venting out in the garage.So I guess you need a Gen II opti for your car which I do not have.
As far as "trouble" the only thing is to make sure the vent hoses are correct if not they will destroy the opti eventually.
Good luck
Nope no problem all covers are interchangable between all years.I have a 93 opti with a 95 cap converted for venting out in the garage.So I guess you ne a Gen II opti for your car which I do not have.Good luck
