I have heddman long tube headers on a 87 L98 motor. My question is has anyone else had a problem getting them to stay sealed to the stock head? I even went as far as putting two of the crushed foil looking gaskets on ( as reccommended by "mechanic") Supposed to provide a better seal. Definately took most of the beer run fund. Anyone got any ideas on this?
After they have warmed up and cooled off, retighten them. Do this everytime they are warmed up for the first few times. After that keep checking them. You will soon learn that checking and retightening is no longer necessary.
Right. i did that right before i started it every time and a few times when it was running. Now it has been about a year and i still have leaks on both sides between 4 and 6 and 3 and 5 coming up towards the hood and out.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This is due for the most part to the thin 1/4" flanges on these headers. This may surprise you, but I've seen the cheap paper gaskets like the ones that come with these work better than anything on them.
Plain old Mr. Gasket header gaskets, work OK with cheap headers! However, in my experience headers with thin flanges require a lot of maintenance to keep them sealed!
I've found copper header gaskets to be better than anything if the mating surface of both the heads and the headers are spotless. If they're dirty though you'll never get them to stop leaking.
Your clue, here, is in the word, "still". Once they leak you may never get them to seal without changing gaskets. The leaking hot exhaust gases often burn a channel in the gasket that further tightening can't fix.
RACE ON!!!
According to the thread he has used aluminum and plain header gaskets so he has changed the gaskets at least once and it still leaks.
His comments about using two sets makes me think that he may have tried one set at first: and leads me to believe that he has an uneven gasket mating surface.
Initial post with Aluminum gaskets
His reply to plain old header gaskets
i tried a set and they blew out. would two sets help seal it better?
I fought header leaks for almost a year on a twin turbo Mustang I built with a buddy. What finally solved it for us was copper header gaskets, and a thin layer of orange RTV on each side.
Your problems may stem from thin flanges, while ours came from back pressure, but that's what cured our problems. You may never get the Hedman's to seal right.
