msd 6al
Old Oct 10, 2005 | 01:33 AM
pr0zac's Avatar
pr0zac
Default msd 6al
well i figured out how to make my msd box work when my car was carbed, then also when it had a commander 950 but i am kinda having a brain dump on how this works with a stock style harness with a dual connector coil. for some reason it just made sense before but now its not working the way i tried it to make it similar to the 950 setup.
Old Oct 10, 2005 | 05:26 AM
93 ragtop's Avatar
93 ragtop
Is this the LT1 coil? If so, just get the adapter from msd and it is a plug and play deal then.
Old Oct 10, 2005 | 07:44 PM
LT4-Z51's Avatar
LT4-Z51
I just put the msd digital 6 plus on my LT4 the wiring harness you can buy is sweet well worth the 30.00.If you start having electrical problems it only takes about 30 seconds to bypass the msd box & go back to stock to eliminate the box as the problem.....
To msd 6al
