L98 Distributor Question
Old Oct 10, 2005 | 11:15 AM
geezel's Avatar
geezel
Default L98 Distributor Question
1986 Vette. I know I've got my distributor 1 tooth off. Timing is set correctly but distributor cap position tells the story. No big deal, right?
Old Oct 10, 2005 | 11:22 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Sure, you can run it like that, but it’s not that hard to pull the dist. and move it one tooth either
Old Oct 10, 2005 | 11:45 AM
scorp508's Avatar
scorp508
Mine is off so much that I moved all my plug wires over one spot. It's fine.
Old Oct 10, 2005 | 11:56 AM
geezel's Avatar
geezel
Old Oct 10, 2005 | 01:21 PM
tiedt's Avatar
tiedt
Cruising
This may be a stupid question, but how can the distributor cap be off a tooth -(?) when it is held in place by 4 screws. There is only one place that each screws on the distributor cap can go.....unless the distributor cap is off by 90 degrees. I have replaced my distributor cap on my 85 twice now and don't ever remember there being a possibility of being slightly off. The distributor cap bolts either lined up or they didn't. It was only a matter of not being 90 degrees, 180 degrees or 270 degrees off.
Old Oct 10, 2005 | 01:26 PM
Morley's Avatar
Morley
Not the cap, the actual distributor is off.
Old Oct 10, 2005 | 01:36 PM
IBEAM700's Avatar
IBEAM700
I think every other person on the planet with the exception of tie understands that when someone says "my distributor is one tooth off" it means the distributor gear, not the cap.
To L98 Distributor Question
