Electric Problems
Old Oct 10, 2005 | 04:27 PM
tforce's Avatar
tforce
4th Gear
Default Electric Problems
1984 Vette,
The battery has a constant draw on it. I disconnected the negative cable from battery. I put a amp meter between the negative cable and the negative post on the battery, it showed a draw of 4.7 amps. I pulled all the fuses and the draw is still 4.7 amps. I unplugged the altinater and still 4.7 amps. Where else do I check?????? : :
Old Oct 10, 2005 | 09:38 PM
woody1243's Avatar
woody1243
Is anything running such as the fan? You can also disconnect the starter/ solenoid and see if that helps. Is a power seat running amock? Check your engine and all other compartment lights to see if they are going off properly, timer could have taken a you know what....
Woody
Old Oct 10, 2005 | 11:13 PM
jfb's Avatar
jfb
At night look for underhood lights, vanity mirror lights, console compartment light. Do you have a radar detector, or an aftermarket alarm or radio or audio amplifier? Check em. There are several circuit breakers and there are about 8 fusible links which you need to check.
Old Oct 10, 2005 | 11:34 PM
severe-1's Avatar
severe-1
How many amps does the VAT's draw?
Old Oct 11, 2005 | 02:15 AM
Morley's Avatar
Morley
a few mA's
Old Oct 11, 2005 | 02:20 AM
zoro's Avatar
zoro
try sitting in the car for a while to make sure everything is off
when I did that I discovered that the heater fan was on
Old Oct 11, 2005 | 02:26 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Try swapping the battery with known good battery.
Could be a dead cell.
Check the starter. Feel it for heat on a cold motor.
Aftermarket alarm system?
Good luck
Old Oct 11, 2005 | 09:30 AM
jeepie91's Avatar
jeepie91
Look behind your battery, there is a junction block that has a bunch of wires attached to it (jump start block) these wires are protected by fusable links, one of the wires comes from the positive bat cable, if you disconnect this cable it will remove power from all the other wires. Check if you still have a draw, if you do then the only things left that I know of are the battery cables, starter, and I think there is a wire that comes from the starter and powers the blower motor (high speed I think)(you could also have a bad ground on the neg bat cable. If your draw goes away when the wire from the pos bat cable is disconnected the you will have to connect each fusable link wire, one at a time until you find the wire causing the draw, then you will have to figure out what that link supplies.
Old Oct 11, 2005 | 05:46 PM
rstackjd's Avatar
rstackjd
Great thread - I'm trying to solve a similar problem on my '88
Would this apply to the '88 as well?
Thanks for the good ideas on things to check.
Old Oct 11, 2005 | 08:00 PM
jfb's Avatar
jfb
Partial quote:
__________________________________
Yep.
Old Oct 12, 2005 | 02:11 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by jfb
Partial quote:
Yep.
But not tforce's 1984. The '84 doesn't have the junction block behind the battery. The fusible links connect at the starter solenoid with the positive battey cable.
RACE ON!!!
Old Oct 13, 2005 | 10:07 AM
jeepie91's Avatar
jeepie91
Ooops, sorry about that, I have a 91 and was not aware the 84's were different. But you can use the same proceedure to try to find the problem, just different connection locations.
To Electric Problems
