throttle body repairs
you can try rockauto.com for a new one.
The first picture is with the shaft in the forward position seated against the bore. The second is with the shaft moved back, you can see the original position, it is now unseated, the vacuum would pull it this direction and allow the air to leak around the plates.
Grab a phone book from the nearest large city, head for the yellow pages, "carburetor". Some of these shops will replace with a bushing or bearing.
Another tactic, "Machine shops".
Try any speed shop and see if they will recommend anyone who repairs throttle bodys.
A non modified engine probably doesn't need a enlarged throttle body.
I suspect they will repair the shaft with no other modification.
Good luck with this repair.
dlmeyers 90 coupe zf6 3speed shocks
I have some play in my original throttle body but this is not the cause, i installed a new throttle body-still same problem.
A mate of mine has an 87 with over 150,000 miles, original T/B, and it idles rock solid at correct rpms!
Still cant find the cause-tried everything i can think of-
Vac leaks, Iac, tps, base idle, cts, throttle cable, ecm signals, ect.ect.ect.
I see some of the other forum members with the same problem installing extra/bigger T/B return springs.Think i'll be looking at doing this next.
dkoldos@ameritech.net
