What is this sensor?
Old Oct 12, 2005 | 12:18 AM
Flyingboy's Avatar
Flyingboy
Default What is this sensor?
I feel like a dunce for asking, but what is this sensor pictured? There are so many similar looking sensors I loose track of them/ can't remember all the acronyms. The plastic housing for the quick clip is missing. So I thought I'd go ahead and replace it.
Old Oct 12, 2005 | 12:24 AM
bogus's Avatar
bogus
that is a coolant temp sensor. The one to the left is the 9th injector temp sensor.
Old Oct 12, 2005 | 01:11 AM
Flyingboy's Avatar
Flyingboy
9th injector, is that the cold start injector?
Old Oct 12, 2005 | 02:18 AM
Morley's Avatar
Morley
Yes. The larger thing is actually called a "Thermo Time Switch" (by GM) and it turns your cold start injector on and off (and regulates its on time) based on coolant temp.
Old Oct 12, 2005 | 09:43 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Not to hi-jack the thread, but which year models use the 9th injector? Is it on all L98's?
Old Oct 12, 2005 | 02:06 PM
Flyingboy's Avatar
Flyingboy
I think it was only 85 to 87? Someone correct me if I'm wrong.
Old Oct 12, 2005 | 02:54 PM
chucks88's Avatar
chucks88
up to '88 I believe as mine had one
Old Oct 12, 2005 | 03:25 PM
scorp508's Avatar
scorp508
85-88 had the Cold Start Injector (CSI) controled by the Thermo Temp Switch.
Is your coolant temp sensor messed up? I can't see the pins on it. I haven't looked at mine in a while, so I can't remember what it actually looks like with the connector off.
Also keep in mind tha the L98 has two of these coolant temp sensors. One (that one) is the one that the ECM uses for its calculations. The other one (in one of your cylinder heads) is used to display the temperature on your digital dashboard.
Old Oct 12, 2005 | 06:13 PM
tigmaned's Avatar
tigmaned
the senor for the temp gauge is right in front of #8 cylinder.
Old Oct 12, 2005 | 08:24 PM
bogus's Avatar
bogus
the temp sensor on the intake is what fires off the fans.
Old Oct 12, 2005 | 10:47 PM
rightofway's Avatar
rightofway
so the fron one is the one for the fans
Old Oct 13, 2005 | 12:36 AM
smacko's Avatar
smacko
with 'BOGUS' it IS a coolant Temperature sensor.
[Everyone else seems to have gone way off topic!!!]
PS; DONT feel silly in asking - I asked the SAME thing about 18mths ago!
Get a replacement, unscrew the old one and apply several wraps of teflon thread tape or better yet as I did; apply a film of pipe sealant or equivalent to the thread all round and screw it back in...Not TOO tight, but firm. You'll find I think (as mine was) that a new wiring connector comes with the GM replacement.
PPS to others; L98's have a cold start injector; it's not a '9th injector' as it serves one purpose only.
Old Oct 13, 2005 | 02:46 AM
RatC4's Avatar
RatC4
Be careful with teflon tape if the sensor grounds through the threads. I have found that it can act as an insulator and make it appear that the sensor is not working.
Old Oct 13, 2005 | 03:04 AM
smacko's Avatar
smacko
...Interesting theory...I would wonder why the sensor needs the 2 wires to it if the body was meant to be grounded...
No probs with mine anyway, using the pipe cement paste, so just incase it IS probably better to use that than thread tape.
To What is this sensor?
