VAT Number Help
Old Oct 17, 2005 | 11:08 PM
JeffM1243's Avatar
JeffM1243
In the 1990 you can go into CCM diagnostics and get the VATS "Key counts" then reference a chart in the factory service manual which tells the key code....Believe this works in the 91's too......
Old Feb 28, 2025 | 01:59 PM
Sumsum22's Avatar
Sumsum22
1st Gear
Default How do you find it? I went to a dealership and they told me they can’t find it
I lost the keys to my 1999 corvette and I went to a dealership but even with the vin they said they can’t find the vat number. That I have to tow the car in and pay them around 200-300 to figure it out. Can someone help me?
Old Feb 28, 2025 | 04:17 PM
WWFRC's Avatar
WWFRC
1999 would be the C5, not a C4.
However, the VATS system is to my knowledge almost the exact same. Do you have a spare key? Per above, measuring the resistance and matching to the table would be the way to go. For a table, just Google "C5 Corvette Vats Table".
Plenty of places to order replacement key blanks from, and just about any hardware store will cut it for you.
If you don't have a spare to measure, you may be better off replacing the whole lot with matching keys, also mentioned above.
Old Feb 28, 2025 | 04:23 PM
WVZR-1's Avatar
WVZR-1
That doesn't sound correct - they won't generally do it for free but would require you to walk in with ID and registration. Some lock shops have relationships also and could help you. The resistance code is supplied with a key request from GM. The code might not work but the resistance code is seldom changed from original. Walk into a dealer with your ID and registration.
