I just finished installation of a Valeo/Fidanza single mass flywheel combo. I am getting a lot of noise from the transmission when I am in neutral and the clutch is engaged. I expected a rattle, but this is extreme(vibration, grinding, seems to load the engine too). The flywheel was match balanced and I don't really have vibration issues when driven. I was to late to read some of the post that recommended to not install this combo on a daily driver, but I am wondering if this is normal or is there a possible tranny issue? Any help would be appreciated.
mine was even match balanced to the rotating assy when i had it installed. this isn't really necessary for L98 apps (per carolina clutch, the source), but i had it done since the whole engine was out anyway, last year.
made no difference. in all likelihood all is fine with your setup, except the flywheel. i assume you do have a matching sprung hub clutch disc.
when you disengage the clutch, about 80% of the racket will disappear.......not necessarily practical at every stoplight for the rest of its natural life.
You know Brett, if you'd tell us a little more about your Vette (in your sig) we might be able to help you out a little more. For instance, what kind of mods are done to your engine, ie horsepower? If it is stock or mostly stock, then a better plan would have been a dual mass flywheel and a stock clutch. If you are going with more than say 400 hp and you want to run slicks, then maybe a custom clutch is in order. The single mass flywheels will rattle the tranny like a box of rocks, especially one with more miles on it. Oh the problems of big horsepower.
