newbeee got ?
Old Oct 12, 2005 | 11:37 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default newbeee got ?
My friend just got a 94 vette as her first vette and I have some questions since I get to repair it.
The abs light in dash is on and the seller said it was from rear center brake light out is tripping the abs in ecm that it has a brake problem. Is this BS or not. Also what is easiest way to replace bulb?
Also the ASR service light is on and wonder what can cause it to come on and are there some things to check to correct it.
I didn't notice this light on when I test drove it but she says it has always been on when she drove it.
This vette has 6spd and lt1 and overall is very nice condition and she got it for 9 grand.
Any help would be greatly appreciated.
Wave on. \ ////
Old Oct 12, 2005 | 11:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since you will be the Mr.Goodwrench on that Vette insist that she pick up a copy of the GM Shop Manual by HELM for it. It has all the info you will need for current trouble shooting and future R&R projects.
I doubt that the hi brake light has to do with the ABS but you can access the bulbs by removing the two screws that are accessable just under the hatch by the hinges. Then you can lift the light assy and remove the top for access to the four bulbs.
Old Oct 13, 2005 | 08:18 AM
thomastl's Avatar
thomastl
Doubt very seriously that a brake light would cause the ABS light to come on. They are not connected.
I have had ABS light on other cars and I always start by cleaning the sensors. Next, purge the brake fluid w/ new. Moisture can cause the ABS pump to not work properly.
Good luck.
Old Oct 13, 2005 | 05:52 PM
cavu's Avatar
cavu
You will need to read the codes to be sure, but the usual cause of the ASR light is a bad wheel speed sensor. This is a PITA, because the speed sensor is part of the wheel hub and has to be replaced as a unit. If this is the root of your problem, there have been a few posts on how to replace the vette hub with a firebird hub which is about half the cost.
Old Oct 13, 2005 | 06:06 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Both problems may be related to the wheel sensor but as mentioned above get the Factory service manual it is the best $100 you can invest for your car.
Old Oct 13, 2005 | 06:37 PM
z28cp's Avatar
z28cp
Unfortunately, Helm currently shows "out of stock" on the '94 manual set....
DaveZ.
Old Oct 13, 2005 | 07:03 PM
joe3906's Avatar
joe3906
Manuals can be bought via the corvette catalogues, such as Ecklers, corvettecentral, and you can also check ebay. LOL.
Joe B.
Old Oct 14, 2005 | 10:31 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
thanks for the advice and guess I will have to check things out. Sheesh I hate electronics which isn't a good thing these days.
Old Oct 14, 2005 | 11:10 PM
Brian9's Avatar
Brian9
Go to the C4 Parts/Wanted section of this forum and post a WTB (want to buy) for the Shop Manuals for the year you want. Someone may have a set laying around they want to get rid of. I just bought a set for my 95 vette off of there
Old Oct 15, 2005 | 01:02 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Check for any Trouble Codes.
Diag. connector above the drivers knee.
[01|02|03|04|05|06|07|08]
[09|10|11|12|13|14|15|16]
Use a piece of wire or paper clip and connect Pin 4 to Pin 12.
Turn the ignition to run (don't start the engine).
Look at the Speedometer display LCD.
Should cycle and display each module and any errors for that module if there are any.
Module 1 CCM C12 indicates no errors
Module 4 ECM/PCM ------ indicates no errors
Module 9 ABS/TCS ------ indicates no errors
Module A Airbag ------ indicates no errors
Repost if you find any Error Codes.
Old Oct 16, 2005 | 08:43 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default pulled codes for abs problem
Pulled codes and got a code only on #9 which was H29. What does this code relate to? Why doesn't the ASR show a code or could it be tied to the H29 code?
My service manual for my 89 states the wheel sensors can be replaced so I wonder can the 94 sensors be replaced also?
Does anyone know of a thread for checking ABS system on a 94 Vette? I saw thread for 87 to 91.
I have not heard the ABS activating or any pedal sensation but have not had it on wet roads either.
I did pull ecm fuse to reset ecm but still have the same asr and abs lights on.
Wave on \ ////
gary
Old Oct 17, 2005 | 12:40 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Regarding changing the 3rd brake light, If it is a coupe like ours, I thought I replaced our bulb by removing the rear license plate and reaching-up behind it and gently removing the nuts holding it to the bumper.
Regarding the wheel sensors, I thought I had read somewhere that just cleaning the surface area of the sensor (where it sticks out of the hub) can fix the problem.
Either the dirt/corrosion/metal filings alter its magnetic pick-up or alter its ground, not sure which, but it made sense to me when I read it somewhere awhile ago (didn't have the problem, but just 'filed' it away in my memory for the future)...
Hope this helps...
Old Oct 17, 2005 | 09:08 AM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default bulb
I did replace the bulb by removing license plate and no the ABS light didn't go off as I suspected it wouldn't.
I also read under texas inspection requirements that an ABS light on is not grounds for failing inspection.
I still need find what codes pertain to.
To newbeee got ?
